Considering H110i GT cooling
Solved by LancerBG,
top is the conventional wisdom however I have done rads at the bottom and front of cases and never had any issues. CPU heat is number one for me and I dont overclock gpu's or ram so its not a big deal. If you install the rads at the bottom you are sucking in or pushing in the coolest air possible. front second and top is actually the hottest air you can push or pull through so while top is conventional its not as simple as that.
Featured Topics
Rogers24 ·
Posted in Troubleshooting0 -
TurkishBTW ·
Posted in Peripherals0 -
1
kennethk ·
Posted in Peripherals1 -
4
BTSHalfLifeAndGmodFan2003 ·
Posted in Storage Devices6 -
6
1
Abaris ·
Posted in Troubleshooting4 -
2
