i only have 3 lines on my signature, and thats all im allowed, im new to using spoilers! how do i make it so i can go on more than 3 lines?
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/341463-spoiler-help/
Try this:
[spoiler=My Current build]i7 6940X Ti etc
i7 6940X Ti etc
https://linustechtips.com/topic/341463-spoiler-help/#findComment-4653047
Try this:
i7 6940X Ti etc
how would i go on a new line>
}else{
https://linustechtips.com/topic/341463-spoiler-help/#findComment-4653055
What do you mean?
They added this feature so that you can't have more than 3 lines in your sig (which was already a rule)
https://linustechtips.com/topic/341463-spoiler-help/#findComment-4653064
What do you mean?
no but i mean your sig has 1 line then 3 lines i cant get that? it only allows 3 for me?
}else{
https://linustechtips.com/topic/341463-spoiler-help/#findComment-4653070
I'm not sure what is going on with sigs since they added that feature..
When I tried to enter this in my sig:
Unofficial Pokémon TCG thread
Unofficial Beginners guide to LTT
CPU: AMD Athlon X2 255 (3.10 GHz) | RAM: Corsair XMS3 2x2GB + random 2x2GB sticks (running at 1333 MHz) | MoBo: Asus M4A89GTD PRO | PSU: Antec earthwatts EA500 (500W)  | GPU: Nvidia Quadro 410 |
Case: Antec Sonata III Paino Black Quiet Midi | Storage: WD Caviar Black 1TB | OS: Windows 7 (Premium, 64 Bit) | Displays:  ASUS VH222, BENQ GL2460
And it said that 3 lines is the max. (even though this returns as 2 lines and a spoiler, so like 3 lines)
I believe it has something to do with the fact that it sees spoilers as multiple lines or whatever.
https://linustechtips.com/topic/341463-spoiler-help/#findComment-4653130
thanks dude!
}else{
https://linustechtips.com/topic/341463-spoiler-help/#findComment-4653193
thanks dude!
I just went to the Bugs and Issues thread and said something about this and got a reply back.
If you want your sig like this:
interesting links: Useful guide/tutorials  (Build Guide
Clipbyte's progress(coding project) (CLICK HERE)
CPU: Intel I5 4690K (stock 3.5Ghz) || CPU cooler: corsair H80i (push/pull) || Motherboard:
You just need to have it like this:
The spoiler begin should be on the end of the last sentence :P
Don't forget to change up the colors again though
interesting links: Useful guide/tutorials  (Build Guide) Clipbyte's progress(coding project) (CLICK HERE) [spoiler='my current build] CPU: Intel I5 4690K (stock 3.5Ghz) || CPU cooler: corsair H80i (push/pull) || Motherboard:
https://linustechtips.com/topic/341463-spoiler-help/#findComment-4653232
interesting links: Useful guide/tutorials  (Build Guide) Clipbyte's progress(coding project) (CLICK HERE) [spoiler='my current build] CPU: Intel I5 4690K (stock 3.5Ghz) || CPU cooler: corsair H80i (push/pull) || Motherboard: [/spoiler]
ill do it later going to watch some T.V
}else{
https://linustechtips.com/topic/341463-spoiler-help/#findComment-4653509
His signature is 3 lines - the first line with links, the second line (the first line of the spoiler) and the third line (the second line of the spoiler)
You're probably seeing the first line of the spoiler overflowing the spoiler box and counting it as a new line, but it's really all part of the first line.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/341463-spoiler-help/#findComment-4653512
