so i'm on quite the low budget and was thinking
3xmsi Gtx960 or one msi gtx980
or will one gtx970 be enough and then later on buy another one
Def not 3xGTX 960.
Probably GTX 970 and maybe later another one or GTX 980
https://linustechtips.com/topic/340294-shopping-advice/#findComment-4639548
Second that 3 960's an awful idea. Your ideal solution would probably 2 970's/
Intel 4790 K - R9 295X2 - Gigabyte Z97-SLI - Corsair Vengeance Pro Black 1866 CAL9 - Corsair HX 1000 -Samsung 850 EVO SSD - Samsung HDD - H100I - Corsair C70 - G400 Logitech - Asus VS247H - WASD custom mechanical and QCKPAD!
Staples of LTT: Getting an 4690 K will resurrect your lost family members, AMD = More heat thus AMD = Satan.
https://linustechtips.com/topic/340294-shopping-advice/#findComment-4639569
3way SLI with a GTX960 is not even possible. This card is single or 2way...
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/340294-shopping-advice/#findComment-4640851
