Hey guys,
So after trying to delid my horrid 4790k I ended up nicking one of the corners and killing it. :angry:
Oh well. Let me pick up a processor from silicon lottery. Went with a 4.8 and this time opted for the deliding service for an extra 50 bucks. The owner is an awesome guy. Killed my 4790, then that night ordered another one. The next morning I noticed he ships from the same town as me. Turns out he lives 10 mins away. Let me save on shipping and personally delivered my proc to my house.
Long story short I want to see if my temps on this one fall in line with other delidded 4790's.
Current settings are 4.7 @ 1.28. Temps maxing at 85, but usually hovering in the 80's using OCCT small data set. 72 F ambient.
Cooling is from a noctua d-14 with plenty of airflow.
Sound about right?
https://linustechtips.com/topic/338964-delidded-4790k-normal-temps/
An NH-D14?
Sounds a little high, considering I'm doing similar temps at about the same voltage albeit different clocks (4.6GHz, 1.295V) on a Dark Rock 3, but I wouldn't worry too much anyways.
An NH-D14?
It does seem pretty high. I'm guessing the issue is no liquid metal or similar material on the die.
I don't know what delidding means, but I know 70 on a Noctua is like rare when it's idle
Pretty sure the OP is referring to load temps and not idle.
That begs the question, do you think Coolaboratory Liquid Pro is worth it over NT-H1 for my CPU's die?
I forgot to mention that I'm not delidded on the i7, but my Pentium is.
It supposedly has Coollaboratory Liquid Ultra. From looking around a bit I'm seeing people say high 60's. Something doesnt seem quite right.
Probably a bad mount.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
OMG that's terrible you don't even need to delid the 4790K it comes with top of the line TIM already from the factory...what a bummer :o
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Tried reseating 3 times already.
Try again.
NT-H1 has pump-out issues. As long as you can cover the row of capacitors with something like epoxy, using CLP wouldn't be a bad idea.
I haven't actually seen any evidence of better TIM used. The TIM Intel used before was top-notch before anyway. Delidding solves the issue of a gap between the ihs and die and not so much replacing a crappy thermal material.
Is there any info on whether or not the ihs is glued back on and if and how it was done?
Are you mounting the NH-D14 tightly enough?
Top of the line ? :D I see lots of people getting up to 25 degrees C drop in temps with the 4790k---> http://www.overclock.net/t/1313179/official-delidded-club-guide
edit: lol actually it looks like the only guy getting a 25C drop isnt even using the IHS haha cooler directly onto the naked die! :D
4670k @ 4.3GHz w/ Deepcool Lucifer | ASRock z97e-itx/ac | 2x4GB G Skill Ares | MSI TFiii HD 7870 @ 1150/1450| OCZ Vertex 4 128GB + 1TB | Bitfenix Prodigy Black | Antec TP-650C
 You'd be surprised. Even at a stable 1.2v, the 4790k likes to vary wildly, mostly because the TIM is far less superior than a known aftermarket TIM like Arctic Silver or the Noctua compound. I'd know, i've tried.
:) Soldered TIM, best TIM. :)
i7 4790k OC @ 4.9GHz | 32GB G.skill Ares 2133MHz | Asus Z97-A | NZXT Kraken x61 | EVGA SuperNOVA 1000W P2 | EVGA GTX 980 Superclocked ACX 2.0 | Fractal Design Define R5
The TIM used by Intel is much better than Artic Silver or NH-T1.The temps are an issue due to the gap created by the glue around the die and not crappy TIM.
uhmmm the 4790k was upgraded to not need delidding. you can actually make your temps worse
cpu:i7-4770k    gpu: msi reference r9 290x  liquid cooled with h55 and hg10 a1     motherboard:z97x gaming 5   ram:gskill sniper 8 gb
 this is true but wasnt the new gen intels fixed to solve the gap problems/heat that the 4th gens had (4770k,4670k)? from what i thought the new gens solved these issues
yes the temps are much better now, you can only f*ck up if you delid those chips.
No, they just improved voltage delivery with some more capacitors.
Delidding can still yield much improved temps. The issue is the gap and not so much the thermal paste.
Try again.
^ This, some people can't get a proper mount with a certain method for applying the TIM, some can't get it with the rice method, and others can only do it with the line method. My suggestion is, try whichever of those you didn't try yet.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
No, they just improved voltage delivery with some more capacitors.Delidding can still yield much improved temps. The issue is the gap and not so much the thermal paste.
I replaced both the glue and the TIM and honestly, i've had almost a 20C drop on my processor. It was only 10C when I kept the TIM on and replaced the glue.
Delidding is pointless without using Liquid Ultra.
I agree, Or liquid pro. Used both and are basically same thing.
Computer Spec: CPU: i5 4690K @ 4.85GHz Delided    Motherboard: ASUS Maximus VII Hero    RAM: Corsair Vengence 2*4GB    GPU: Gigabyte G1 Gaming GTX 970    PSU: Corsair RM650    Boot Drive: Crucial MX100 256GB SSD    Storage: 1TB WD Blue HDD   Case: NZXT H440 Red and Black
Cooling: EK PWM D5 Pump & EK 140ML RES Combo unit , EK Supremacy Evo CPU Block , 360mm Alphacool Radiator , 3 Noctua NF-F12 Fans on the radiator , Some fancy fittings
