Computer suddenly using 70%+ memory without anything running
Go to solution Solved by Baeyeon,
I restarted but it didn't fix it. What actually fixed it was system restoring O.o Thanks everyone!
My memory for some reason is constantly above 70%, and when CS:GO is open, my CPU is 100% and my memory is 95%+. Does anyone know how to fix this? Please help!
Specs:
* 4690K running at 4.2Ghz @ 1.2V
* 8GB of RAM
* 840 EVO 250GB
* 1TB Barracuda
* Windows 8.1 Pro
* R9 290 Tri-X 4GB
No malware was found when scanning
Have you tried turning it off and on again?
nice, i got that same problem too. I will silently follow the thread.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
Run a Malwarebytes scan just incase its some sort of secret mining virus. If its no then check if your motherboard has a Realtek LAN controller as thoose drivers are well known to have memory leaks (so update it).
Quack 🦆
Are you using Norton? My laptop came preloaded with it and it was very power hungry. I uninstalled it and the laptop stopped crashing and slowing down. Also, I might sound like a smart Alec, but have you tried going to Task Manager and clicking More Details at the bottom left corner (if you haven't yet done so) and then going to Processes and finding the most power-hungry program, under the memory column? That might solve it because it did for me.
No seriously, guys, turn it off and on again. It will fix it. This is just a stuck process that didn't shut down correctly.
You can also use task manager and "show system processes" and look for the one that is using tons of CPU and just end it.
But restarting is easier if you dont want to mess with the processes...
Go to your task manager and sort Processes by CPU % and see with the highest value at the top and you can find out whats causing it. I have a similar problem. When i open my Mail App the communication services uses 75%-90%. I t might be something similar for you.
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
The op's problem was fixed, so I think it is fine to ask, I have to restart all 2 to 3 days in Widows 8, because of that error. Normally I could leave the PC on for weeks and this wouldn't happen. Any idea what is wrong? Shoupd I make a new thread with screenshots of the task manager?
find the process thats getting stuck using all your CPU, google it, find the parent program of that process, reinstall that program
