As the kraken x40 is a 140mm rad cooler it will perform best.
As long as you can fit it in your case.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/3370-closed-loop-help/#findComment-42664
I'm quite satisfied with my H80 in my folding rig and its compatible with just about any case...
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
https://linustechtips.com/topic/3370-closed-loop-help/#findComment-44122
The x40 is about 25mm thick - the Antec is about 50mm thick. So you trade performance of the x40's 140mm versus the thickness of the 920's 120mm. All in all - you may see a 1-2 degree difference, + or -, between these two. I have an Antec unit, ships with two fans, so if using in Push/Pull - just ensure you have the clearance...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/3370-closed-loop-help/#findComment-44157
excuse me to say, but neither of them are the best...
they all have their pros and cons on using them.. and
usually for a lil more in saving and spending a better solution
may be found.
s'more information may help with better answers..
rig specs are always nice..
airdeano
https://linustechtips.com/topic/3370-closed-loop-help/#findComment-44222
