850 Pro
Wingfan
I just did a fresh Win install on this new drive....here are the numbers, shouldnt it be faster?
For what i do, this is plenty fast enough. But if it should be faster than i want that speed :)
post-9191-0-63540000-1427556162_thumb.jp
Ryzen 7 5800X3D, Corsair H105, Gigabyte x570 Aorus Elite, Corsair Vengeance 32GB 3600MHz, EVGA RTX 3070Ti FTW3, Samsung 850 Pro / WD SN850 / OCZ Trion 150
ASUS MG279Q, Corsair Carbide 275R
Those speeds are fine.
When everything else Fails,Crowbar IT. - Half-life
Being a Linux user is sort of like living in a house inhabited by a large family of carpenters and architects. Every morning when you wake up, the house is a little different. Maybe there is a new turret, or some walls have moved. Or perhaps someone has temporarily removed the floor under your bed." - Unix for Dummies, 2nd Edition (Found in the .sig of Rob Riggs)
Seems to be pretty good to me, my 850 pro 256 gb does 130 MB/s write in the 4k compared to yours , but the rest of the numbers are pretty similar to yours
Huh. That sucks. But you ain't at the level of my 840 EVO!
Advertised speeds -
500 write
500 read
97000 iops read
70000 iopsz write
Actual speed
200 read
200 write
29000 IOPS read
20000 IOPS write
And good luck contacting Samsung support, they can't be shitier
Lets all ripperoni in pepperoni
There fine speeds my 850 runs in or around that if there a little low than they should be thats fine and its hardly not even noticeable :)
CPU: FX8350  GPU:  Sapphire radeon r9 290x Tri-X  Mobo: Gigabyte 970A-UD3P  RAM:  Corsair Vengence 1866mhz 8GB  PSU: Corsair CX750M
HDD:  Western Digital Caviar blue 1TB  SSD:  120Gb Samsung 850 Evo
optimized and its a little better......
post-9191-0-61790700-1427561540_thumb.jp
thats perfect :)
