i would get an i3 4160/4150
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
Heey guys,
Which cpu is better for sony vegas video editing, Intel Pentium G3258 or a cheap Intel i3?
If there is a better alternative for rendering let me know ;)
Thanks!
i3 for sure cause hyperthreading.
and intel quicksync will also help quite a bit
For a rendering machine, you are going to want an FX processor with that small of a budget.  Either an FX6 or FX8.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
If you don't mind looking at Used, the X5650 is a great option.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
Heey guys,
Video editing comes down to CPU performance.  Technically the G3258 will probably get you better single threaded performance if you are able to overclock it a ton.  However that will require adequate cooling.
On the other hand, i3 will be great for encoding but look into if Vegas supports Quicksync for encoding.   Last I checked it doesn't.. but it would help.
@TechBenchTV
Ex-NCIX Tech Tips Producer.  Linus hates my scripts.
