Fan question.
Go to solution Solved by DudeWazap,
Yes you can.
You can plug in both a 3 pin or 4 pin fan.
Hey guys, I was wondering. Can I plug a 3-pin fan into a PWM male connector on the mobo? Thanks in advance
| i5-4670k @ 4.2Ghz | Corsair H100i | Gigabyte Z87X-UD4H | Corsair Vengeance Pro 8GB | ASUS Geforce GTX 770 |
| Samsung 840 Pro 128GB | WD Black 1TB | Corsair AX760 | Fractal Design Define R4 Black w/ Window | Corsair AF140 x2 |
| Windows 8.1 | ASUS 23" 1080p monitor | CM Storm Quickfire Stealth- MX Blue | Logitech G9x | Logitech G930 |
https://linustechtips.com/topic/33627-fan-question/
Yes you can.
Ty! I was wondering because the NZXT fan hub has a 3-pin input cable, and my mobo only has 1 PWM fan header.
https://linustechtips.com/topic/33627-fan-question/#findComment-430737
