yes.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/336021-psu-help/#findComment-4584883
Will a 650 watt psu power this
GPU:Gtx 760
MOBO:Asus Z97-A ATX LG1150
CPU:i5 4690k
Im pretty sure it will but i dont want to mess anything up and regretting not checking
Depends on the power supply. There are some cheapo PSUs which can't safely output the wattage listed.
https://linustechtips.com/topic/336021-psu-help/#findComment-4585282
https://linustechtips.com/topic/336021-psu-help/#findComment-4592821
Nope, just another mediocre sirtec unit. For the same (or cheaper) price you can get a better quality PSU.
For that system you don't need 650W. This 550W Rosewill Capstone is at a great price:
Total: $39.99
Generated by PCPartPicker 2015-03-27 20:23 EDT-0400
https://linustechtips.com/topic/336021-psu-help/#findComment-4592823
