fan splitter
https://linustechtips.com/topic/335817-fans/#findComment-4581459
Hmm.. You'll be probably able to power three fans from a single connector but I could be wrong. The last time I tried it on a crappy mobo it didn't work. Check the specs on manufacturers website and find out the wattage for the fan connectors. You can easily power two fans from a single 4 pin but you need a splitter.
For example (do not read this):
A fan needs 2.3 watts of power. Your motherboard 4 pin can provide 8 watts of power. You need 3 fans. 2.3 x 3 = 6.9 watts. Result??
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/335817-fans/#findComment-4581530
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/335817-fans/#findComment-4586022
