hi guys
i have been stuck with this shitty laptop and i want to buy a new pc but i dont have much money so i put this together. can you guys tell my if it will be any good and what games on what settings it can play or maybe a suggestion for better parts. here is what i have so far:
AMD A8-5600K Quad Core 4 x 3.6 GHz Processor (CPU) boxed Socket: AMD FM2 Asus F2A85-V Pro
motherboard Socket AMD FM2 Vormfactor ATX motherboard chipset AMD A85X FCH
Gigabyte AMD Radeon™ R9 270X Windforce Overclocked 2 GB GDDR5-RAM PCIe x16 DVI, HDMI, DisplayPort
Corsair Vengeance CMZ16GX3M4A1600C9 16 GB DDR3-RAM  1600 MHz 4 x 4 GB
Thermaltake Berlin 630 W power supply
dont worry for storage
Intel Core i7-4960X Extreme Edition 3.6GHz 6-Core Process/ Asus Rampage IV Extreme EATX LGA2011/Corsair Vengeance Pro 32GB (4 x 8GB) DDR3-2800/Intel 730 Series 480GB ssd/Western Digital Red 3TB hdd/ 2 X EVGA GeForce GTX Titan X 12GB/Corsair 1200W 80+ Platinum/3 X LG 31MU97 60Hz 31.0" Monitor/ Razer BlackWidow/Razer DeathAdder   AKA: MY LITTLE FRIEND
https://linustechtips.com/topic/335730-pc-build-help/
hi guys
would be better with a pc part picker link but I'll do my best to analyse this
cpu: I would go for a g3258 if I was you it's more flexible than this old apu
motherboard: anything to go with the g3258 really
gpu: the gpu is fine it will run anything pretty decently
ram: it's overkill if you're not using 4 thing in the same time and keeping 100 tab open (which I do xD) you can downgrade to 8Gb it will run the same and it'll save you some money
psu: the evga 80+ bronze 600W would be a better psu for cheaper (I think)
https://linustechtips.com/topic/335730-pc-build-help/#findComment-4580262
What's your budget?
around 800 euros / 880 dollar
https://linustechtips.com/topic/335730-pc-build-help/#findComment-4580320
nice thank you
https://linustechtips.com/topic/335730-pc-build-help/#findComment-4580338
YOU cannot match up an A-series CPU with a high end graphics card because the AMD A-series is integrated with a GPU.
You can do an A-10 build for about $400, I will throw it together for you if you want.
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
https://linustechtips.com/topic/335730-pc-build-help/#findComment-4580793
hi guys
Here is a nice build that features the AMD A10 APU.
this setup can run BF4 at around 40-60 FPS on High settings.
http://pcpartpicker.com/p/8pxR6h
https://linustechtips.com/topic/335730-pc-build-help/#findComment-4580821
thanks
https://linustechtips.com/topic/335730-pc-build-help/#findComment-4589022
