you will need to set a custom SLi profile in the nVidia Control Panel
newer drivers should have the profiles in build in the control panel
otherwise it just a matter of selecting the game.exe and force SLi
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/335490-multi-gpu-question/#findComment-4576817
you have 2x 690?
690 is basically 680 x2
https://linustechtips.com/topic/335490-multi-gpu-question/#findComment-4576820
I have a 690 and im wondering if theres a way to get the two gpu's to work together, they do in some programs and games but is there a way to get them to work together in games like cs:go, smite, etc?
The game must supports SLI. Always update your driver to the latest and pray hard the games you play have support for it.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/335490-multi-gpu-question/#findComment-4576887
you have 2x 690?
A 690 has two GPUs on the PCB.
https://linustechtips.com/topic/335490-multi-gpu-question/#findComment-4576906
right
this is the Titan Z's and Asus GTX760 Mars's Father
https://linustechtips.com/topic/335490-multi-gpu-question/#findComment-4576921
Don't most modern games support SLI? I haven't faced any problems with SLI support for games, then again I mostly play AAA titles and MMORPG
CPU Intel Core i7-5930K @ 3.5 GHz Motherboard Asus X99 Deluxe RAM Corsair Vengeance LPX 16GB @ 2800MHz GPU 2 x Gigabyte GTX 980 G1 Gaming (SLI)
Case Corsair Carbide Series Air 540 (Gray) Storage 2 x 1TB 850 Pro, 2 x 4TB WD Black PSU Corsair AX1500i (1500W) Display Asus PG348Q Ultrawide - G-Sync
Cooling Corsair Hydro Series H100i Keyboard Razer BlackWidow Chroma Mouse Razer Mamba Sound Logitech G633 Operating System Windows 10
https://linustechtips.com/topic/335490-multi-gpu-question/#findComment-4577005
Most but not all. I remember there is 1 AAA game that still doesn't support SLI. Can't remember which one thou. (Or maybe it have been updated already). Haha.
https://linustechtips.com/topic/335490-multi-gpu-question/#findComment-4577022
