Problem:
I have my laptop (1080p 16:9) connected to my TV (1080p 16:9). However, while the rest of the UI seems to be scaled exactly the same, the Start Menu, depending on the screen scales differently.
I would like to have the smaller laptop start menu on my tv.
LAPTOP DISPLAY:
TV DISPLAY:
Screen settings are set as following:
I checked the scaling settings, they're both the same on both screens as well.
System Specs
  • CPU Intel Core i7-4710HQ 6MB
  • Motherboard XMG Model C504 v1.0
  • RAM 16Gb DDR3 1600Mhz Crusal Ballistix Sport
  • GPU NVIDIA GeForce GTX 870M 6144MB GDDR5
  • Storage 2x 256Gb SanDisk X110 mSATA SSD | 2x 500Gb HDD (RAID1)
  • Display 15.6" Full-HD Matte AHVA/IPS Monitor
  • Operating System Windows 8.1 Pro 64bit
RuneScape is still the best MMO ever made.
Program on Mac | Game on PlayStation | Homelab on Ubuntu
I do believe this is just what happens when you connect to a tv, I can see it allows to have a better sight when using the start menu, and I have not found any way to fix this.
It may just be what Windows does to help with screen compatibility.
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
Ah, damn :(
I hope it isn't tho.
I've tried going into settings>personalize too, but it didn't help much either.
We'll see if anyone else replies, if not I'll mark your answer as solved.
