before ordering my Titan X, help?
Go to solution Solved by Oshino Shinobu,
You could run it with 2GB if you wanted to. You don't need to upgrade.
It's a typo on their site. The correct info is in the manual: http://www.nvidia.com/content/geforce-gtx/GTX_TITAN_X_User_Guide.pdf
It says it requiers "24 GB system memory (48 GB or higher recommended)"
i have 12GB of Corsair Doms 2800 does that mean i need to upgrade me ram?
Im pretty sure linus test bench only has 16 or something and that worked so u should be fine me guesses!
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
Nope, fairly you can use the titan x with a system with only 8GB of RAM, probably even 4GB or lower too. (Not that you'd want to, I'd say 8-16GB is a good amount.)
