I've ordered a soundbar + subwoofer to upgrade my TV speakers
I have Panasonic TX-P42ST60B
The soundbar I'm getting doesn't come with a optical cable so will have to buy serpate
But does come with RCA cable for normal stereo sound.
Does my TV support that? I can see the RCA connections on the back of the TV but no indication if they are out or in.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/332959-audio-connections/
Not sure, but you'll be able to buy a 3.5mm to RCA adapter.
My TV doesnt have a 3.5 socket on it.
And the manual doesnt help, it doesnt tell you.
https://linustechtips.com/topic/332959-audio-connections/#findComment-4518484
https://linustechtips.com/topic/332959-audio-connections/#findComment-4518504
