No. Plug a turned off psu into a connected socket. Otherwise you're good.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/332162-grounding-quick-help/#findComment-4508755
Why would the wall socket have to be on. It can be off, it will still ground the PC.
idk, I've just been told that by everyone I've asked, and multiple google searches say to do it, so I did it and I was fine
https://linustechtips.com/topic/332162-grounding-quick-help/#findComment-4508785
This really depends on the country as Ireland and the UK have a dedicated ground connector on the socket that is always used...(bar double insulated appliances) while other countries have sockets where they might, might not use a dedicated ground and strictly speaking there are 2 types of ground used in electronics. in ireland and the uk it doesnt matter at all if the socket is in the on or off position you will still be grounded and as for the psu it doesnt matter if its in the on or off position on the switch as unless you bridge it it wont turn on.
X79A GD65 (8D), 3820, 7770, 16GB (1600Mhz cas9), 850watt(ocz zx), storm trooper, h100, xonar xense, sp2500, pc350, asus PA248Q LG 22'' ips, razor black-widow ultimate 2013, 120GB intel 520 series 128GB crucial M4 2*3TB barracuda 2*1TB barracuda 2TB Hitachi
https://linustechtips.com/topic/332162-grounding-quick-help/#findComment-4508823
The ground must be actually connected though. You can't plug in to a dummy outlet.
https://linustechtips.com/topic/332162-grounding-quick-help/#findComment-4508834
So I'm kinda scared to ground myself and I want to make sure I'm doing this right. Plug in my psu into a turned off power socket. Alligator clip to the metal fan outside, Wrist strap on. then im safe and continue building?
I have a anti-static wrist strap that plugs directly into the wall socket. Those are usually the safest ones as you dont have to worry about if the object you attach youself to is grounded or not.
Im so patriotic, I piss red white and blue. My doctor told me it was pancreatic cancer, I told him to SHUT HIS COMMIE MOUTH.
-A shotgun wielding redneck
https://linustechtips.com/topic/332162-grounding-quick-help/#findComment-4509009
I just hook it up to the metal part of the table I'm working on
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/332162-grounding-quick-help/#findComment-4514869
Static shock Is always going to be a difference in voltage between you, and what you're touching. As long as you regularly touch some bit of metal of the computer your building (pretty much unavoidable) you'll be fine. Linus's bit about having an ESD on his ankle is so much Bull S*%t. if you don't believe me check his garage war videos.
https://linustechtips.com/topic/332162-grounding-quick-help/#findComment-4514879
Or don't bother, my Western digital caviar 365mb hard drive still worked when i threw it out. Had been in about 20+ machines.
My Nvidia MX440 worked fine when i threw it out. Had been pulled from and inserted in to systems probably 50+ times.
Who here ever actually broke something with static electricity?
Don't go scooting around the supermarket in your novelty Homer Simpson slippers whilst rubbing balloons against your shell suit before you start needlessly prodding your PC's delicates.
https://linustechtips.com/topic/332162-grounding-quick-help/#findComment-4518489
