Howdy folks, I'm considering popping a Nepton 280L onto my CPU and it got me thinking "Why leave my GPU dry?" So not desiring a custom loop I'm wondering if anyone here has experience with any of the (rather limited) options on the market for this.
I'm not in any dire straits since I ditched the awful cooler PowerColor put on my 7870XT Tahiti LE for an Accelero TT II early on, but I'm just poking at the idea of taking the dip. (PowerColor fit this nearly 200w TDP card with a single 92mm fan and a curve that let the VRMs roast!)
So fire away, are sealed/AIOs for GPUs at a point where they're good, or should I leave my perfectly fine GPU cooler alone?
1. Overclock until the magic smoke comes out. 2. Modify until broken. 3. Fix and repeat.
4670k - 16GB - 290X - 1440p Freesync
https://linustechtips.com/topic/331899-sealedaio-gpu-cooling/
Just buy a G10 and x41 or x61 or whatever radiator size you can fit in your case.
https://linustechtips.com/topic/331899-sealedaio-gpu-cooling/#findComment-4505831
Closed loops on GPU's are a becoming a big thing now. None of the hassles of a custom loop with all the performance benefits. If your card runs at 75C+ right now during gaming it will top out at like 50C once you strap a closed loop to it. I personally would invest into some low profile heatsinks for the VRM to go with the Kraken G10.
Kraken G10 = $29.99
Corsair H50 = $59.99
So yeah it's not going to be exactly cheap to do. Personally for the card that you have I wouldn't invest $80 to better cool a card that's only worth twice that. If you're not having heat issues then I would skip out on water cooling it and save for a bigger card first.
https://linustechtips.com/topic/331899-sealedaio-gpu-cooling/#findComment-4505899
I was just about to post this. You definitely need something to cool the other chips, or you won't be enjoying the card for long.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/331899-sealedaio-gpu-cooling/#findComment-4505957
Kraken G10 = $29.99
The only reason I haven't made the move to a new card is because I'm waiting for the next wave of adaptive framrate stuff. I know spending ~$80-$100 on this isn't really super sensible, but I'm not overly worried on that front. As soon a 1440p IPS Freesync panel hits the market this GPU gets retired and I'll be slotting in a new card to drive that. As for the case my goodies are stuffed into an R5 so I've got tons of room.
https://linustechtips.com/topic/331899-sealedaio-gpu-cooling/#findComment-4520846
Saw this thread after having the exact same Idea myself.
and remembered this video
Watch this : www.youtube.com/watch?v=LM3DyUqWWns
The main man has all the answers.
:D
edit* link wasnt working,
edit 2* Look at his face. just look at it.
Cpu : AMD Ryzen 3 1200 (3.8Ghz), Motherboard : Gigabyte AB350 Gaming 3 - RAM : 8GB DDR4 2933 Team (Vulkan) memory, GPU : MSI GTX 980 4GB Case : Antec P50, Storage : 120GB Samsung SSD, 3TB WD Blue, PSU : 530w Thermaltake SPS-530MPC, Cooling : Artic freezer Pro 7, OS : Windows 10.
https://linustechtips.com/topic/331899-sealedaio-gpu-cooling/#findComment-4524163
