AX, but its obviously going to be more expensive.
a 750W PSU is more than enough for that build, you could add a second or third 980 if you wanted
550-750 should be plenty, higher part of that range if you plan to SLI.
The RM series are a great choice.
When it comes to PSUs I always look for the cheapest one I can find at the Time, from a well known and well rated brand, with at least an 80Plus Efficiency rating.
And if you've got a case on the smaller side, get Semi or Fully modular.
-snip-
AX better, but more expensive. RM honestly isn't all that great. They're above average, but there are many that perform equal or better from better OEMs at lower prices.
Unless you plan on SLI, anything over 600W is enough for you. Cooler Master VSM Series is good.  Check out the VSM650, VSM750, or V850 models. 650 and 750 are semi-modular, and 850 is fully modular. And they're all made by Seasonic. Though without knowing your country, I can't comment on price.
What country are you in that you only get good service from Corsair and Cooler Master? Those two make great PSUs, but if you're limited to those 2 brands, =(.
Titan: Intel Core i7-5820K | ASUS X99-A | Crucial Ballistix Sport 4x4GB DDR4-2400 | ASUS Strix GeForce GTX 970 | OCZ Arc 100 2x256GB in RAID 0 | Seagate Barracuda 2x2TB in RAID 1
EVGA SuperNOVA 750 G2 | Fractal Design Define R5 Titanium Window | Phanteks PH-TC14PE | ASUS BW-12B1ST
What about the AX series?
Corsair cooler Master and I guess seasonic to an extent
Btw I live in India where everything is atleast 20% more expensive and 100% worse after sales service!! ( 5820k costs 500$)
So ax or v series is my best bet?
Nope no sli!
www.Primeabgb.com
It's a trusted shop don't go above rs 15000 (250$)
Well, the majority of the unit I had clicked on is out of stock...
A quality 550w can power your system. Something like the Antec True Power Classic 550w (Seasonic G / S12G unit internally) for example. But that seem to be out of stock. You can get the 650w variant for 700 INR / ~$11 USD more though: http://www.primeabgb.com/antec-truepower-classic-series-tp-650c-power-supply.html
The Antec VP650PM may be an option as well but has a shorter 2 year warranty : http://www.primeabgb.com/antec-vp650pm-650w-power-supply.html
Here's a review of the non-modular VP550P: http://www.techpowerup.com/reviews/Antec/VP550P/2.html
A strictly Corsair or Cooler Master recommendation would be:
The Corsair CS650M: http://www.primeabgb.com/corsair-cs-series-modular-cs650m-650w-power-supply.html
It's not build as well as the Antec TPC, but it does offer modularity and will power your system.
The RM650: http://www.primeabgb.com/corsair-rm-series-rm650-650w-modular-power-supply.html
Likewise with the CS650M, it's not build as well as the TPC, but it does offer full modularity as well as a quieter operation.
Everything else is either out of stock, not very good, or I'm overlooking something.
Thanks! I was looking at more expensive options like the hx and ax and V series
But looks like the others are great too!
Don't worry about the out of stock thing
IF you can visit it's normally in stock they are just lazy!
