My Asus Z87-A Motherboard has the Bios Version 2103 installed. I did all the cmos reset stuff Asus support wanted me to do. Still, I can not get the Pentium G3258 to work. It will always give me the red CPU led.  @Asus support cut me of 3 time in a row.  :angry:
Anyone got a idea?
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
https://linustechtips.com/topic/331615-asus-cpu-error-led-only-when-using-g3258/
you need to flash your board to the haswell refresh
to Version 2004? It says supported since , so what I understand is, that it should also work with anything 2004+
to Version 2004?
to the 2014 verson
BIOS updater for New 4th Gen Intel Core Processors
Before using the new Intel 4th Gen Core processors, we suggest that you first download the BIOS updater for new Intel 4th Gen Core Processors and then update the BIOS using this tool.
to the 2014 verson
before I had version 1802 http://www.asus.com/us/Motherboards/Z87A/HelpDesk_Download/
Run this first:
Version 2.00.02
then try different BIOSes
Run this first:
Version 2.00.02
also how are you installing these updates?
I have no OS on the board. I used the EZ Flash tool of the Bios. To install the update, I have to take my main PC apart and put the i5 into the Asus board.
Your latest bios is 2205 not 2012 http://dlcdnet.asus.com/pub/ASUS/mb/LGA1150/Z97-A/Z97-A-ASUS-2205.zip
International site is more updated then the regional one. And had that error before. Press clear cmos then wait till the fans spin up and hit the mem ok! button.
Z87, not 97  ;)
Woo ups  :ph34r: Right its 2103 http://www.asus.com/de/Motherboards/Z87A/HelpDesk_Download/Still you can try the mem ok button. That worked for me if you had xmp enabled before the flashing.
nope, still nothing.
Anyone got an idea? Asus support isn't really helping.
Do you have the latest BIOS on that board? Is that BIOS somehow inferior to 2004?
When I update the Bios, does it make a completely new flash, or does it just add things like Windows update does?
Shouldn't 2103 contain all the CPU data from 2004?
now more people are online, so BUMP
