According to Gigabyte my GTX 970 G1 should top out around 1329Mhz on the core but under load my max power usage is only 70% and my boost frequency is around 1400+. When I add full voltage I get around +25mV and I can easily get another 100Mhz out of the core to bring me topping out at 1505Mhz and still only be around 71% power usage on the card. Did I get a good overclocker or do all cards act like this?
I heard some people hardly getting past 1250Mhz and some getting way over 1350Mhz so I'm not sure how well this card overclock.
https://linustechtips.com/topic/330863-gtx-970-g1-maximum-boost-frequency/
seems like you got an good overclocker
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
They all seem to act like this, 1500 on core is about normal for a g1, slightly better for other cards. Of you hit 1500 with 0 added volts very good, hit 1600 with/without extra volts, you did very well. Temps really should be sub 65c most the time.
