My Build
Parts List:
  • CPU:                 AMD FX-8350
  • CPU Cooler:    Corsair H100i
  • MOBO:             MSI 970 Gaming ATX AM3+
  • RAM:                G.Skill Sniper Series ( 2x4gb ) DDR3-1866
  • HDD:                 Segate Barracuda 1TB 7200RPM
  • SDD:                 Samsung 850 128GB
  • GPU:                 MSI GeForce GTX 970 4GB
  • Case:                NZXT H440
  • PSU:                 Antec HCG 750w 80+ Bronze
Peripherals:
  • Keyboard & Mouse:    Cooler Master OCTANE Series
  • Monitor:                       HP 2311x
  • Speakers:                     Insigana Desktop Speakers
Pictures:
My Questions:
  • How Do you feel about the CPU Cooler?
  • Is Cable Sleeving worth it and if so What type of cable sleeving should I get?
  • How Well will the FX-8350 Actually run with Multi-Threaded Programs such as: Cinema 4D, 3DS Max and Adobe After Effects?
  • What would you look forward to into this build for future improvements?
  • If I were to Switch to Intel What MOBO & Processor would I Switch to that would still be Optimized for the software im currently running ( Ex. Cinema 4D, 3DS Max & Adobe AE )
Just Started a new YouTube Channel!
My Build: http://linustechtips.com/main/topic/330097-first-build/
~ Being creative and inspiring other is my Drive and Motivation ~
https://linustechtips.com/topic/330097-first-build/
Name for build :AMD GARBAGE  v 8350
Looks like a pretty nice build, quite upsetting to see a 8350 along with a 970, but whatever.
I can't give you any advice really since you already ordered everything.
Good luck with your build!
p.s: AMD isn't terrible, i own it myself, i just feel that there are just much better performing options for slightly more.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/330097-first-build/#findComment-4481144
  How do you feel about the CPU Cooler? This was one of the most debated parts about my build as I know AMD Processors tend to produce a lot of heat.
https://linustechtips.com/topic/330097-first-build/#findComment-4481221
Heat is usually more than intel but most of the time it is over exaggerated.
The cooler is perfectly fine, will run nice and cool.
https://linustechtips.com/topic/330097-first-build/#findComment-4481251
Looks okay, a bit overkill on the psu but that's fine.
At the price of the AMD FX-8350 you were better off just going intel but it's still a nice CPU.
Can't really say much since you have already purchased stuff, but looks nice overall.
Im Going to be using this PC For more towards Multi-threaded programs such as, Cinema 4D, 3DS Max, Adobe After Effects ect. which is why I ultimately decided to purchase the FX-8350.
https://linustechtips.com/topic/330097-first-build/#findComment-4481261
That's fair enough, at least you researched your stuff first :P
Should be a nice system when it's up and running.
https://linustechtips.com/topic/330097-first-build/#findComment-4481276
  • 2 weeks later...
once you get it all together and name it when your OS prompts you to, you should call it Aguza
why? because why not?
well.... i just googled the name i made up. it's a soccer player... FUUUUUUUUU
no more original names in the world.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/330097-first-build/#findComment-4585721
