so my 270x (xfx double dissipation) is sitting around 70c in the War Thunder hangar, just the hangar
here is the screenshot, any suggestions?
post-123428-0-81541000-1426606694_thumb.
and BTW its idleing at 50c, this has not happened before
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/329770-unusual-high-temps/
70 degrees C seems fine, but if you are worried look into the airflow and be sure all cables are out of the way
https://linustechtips.com/topic/329770-unusual-high-temps/#findComment-4476851
How much is the temp in game lol.
Like on a match.
let me find out real fast
the highest is 75, that is fine i guess, war thunder y u do dis? you got me worried
first time in game and in hangar temps are the same
https://linustechtips.com/topic/329770-unusual-high-temps/#findComment-4476866
