This might seem really basic and common knowledge, but this is my first time I've looked into audio stuff, so bare with me..
How do I hook up multiple audio outputs (TV, speakers & headphones) so they all play simultaneously?
Connect them via a splitter. http://www.amazon.co.uk/Belkin-MixIt-Rockstar-Splitter-Headphone/dp/B0017VKV2I/ref=sr_1_2?ie=UTF8&qid=1426356730&sr=8-2&keywords=splitter
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454482
just plug them all into your PC and set them to all play the same audio stream in your sound settings
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454485
I'd like to know where you think this setting is, mostly because it doesn't exist.
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454489
you need a chip that support it like the alc 1150
has 7.1 out + 2
if im right ? right guys ?
will it work on surround tv ? x3 hdmi outputs with sound ?
When i'm not playing PC games i'm playing with my PC parts  Fans,Pumps,Filters,  :wub:  :wub:  :wub:
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454515
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454538
also i have a sound card, so i can have more outputs of the same audio stream if I enable them in the windows sound settings
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454547
hey any way to connect analogs out to hdmi or spdif ?
will spdif S2N will be same lower or higher then the analogs ?
and so about the hdmi ?
what is better for best connection S2N HD streaming ?
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454564
No, that setting is for the front and rear outputs. It does not involve the separate HDMI sound drivers.
That is for playing different programs across different outputs (according to the description), not the same output across multiple outputs. Correct me if wrong.
Even if OP had the chips, software, and drivers to support it, it's only 2 outputs, while he needs 3.
I'm not sure I understand what you're asking. What is S2N?
You can only output a sound source through one HDMI or S/PDIF "device" at a time with windows. Probably your best bet is to get an optical "splitter" if you're wanting three TV's to play the same sound stream through their integrated speakers. An HDMI solution would involve separating the audio from the video signal before splitting and then recoupling with the three distinct video signals (imo too complex to bother trying).
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454611
signal to noise
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454618
signal to noise
Ah, that's usually denoted as "SNR"
Both HDMI and Optical support bit depths up to 24. Higher bit depth allows for a higher SNR, but 16-bit (CD standard) offers 96.33 dB of SNR which already surpasses human hearing capabilities.
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454670
right signal to noise ratio
the alc 1150 offers 115db snr
and my Audigy 4 pro 124db snr
you say that the spdif will be better ? or lets say a pcm signal (on 16bits)
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454678
Those specs are probably for the analog outputs. Digital SNR is irrelevant because the noise is discarded by whatever device is reading the digital signal.
S/PDIF will be easier to split into three cables to you three TVs. :)
Cheap solution is two of these: http://www.amazon.com/C2G-27027-Toslink-Digital-Splitter/dp/B0002344GG/ref=sr_1_3?ie=UTF8&qid=1426359271&sr=8-3&keywords=optical+splitter
Expensive solution: http://www.amazon.com/Splitter-Distribution-Amplifier-Distributor-Multiplier/dp/B00GEG1KO4/ref=sr_1_8?ie=UTF8&qid=1426359271&sr=8-8&keywords=optical+splitter
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454711
Thats true...
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454714
I don't own 3 tv im sorry if I confused you just gave an example
I wish I did
so no difference between spdif and hdmi coax ? in SNR and lag in ms (I don't know the word for it the time for a signal to arrive like ping)
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454743
I wish I did
HDMI can carry 192kHz 7.1 audio. S/PDIF can do 192kHz stereo, but sometimes 192 doesn't work on cheaper devices. Optical has the issue of jitter, but also only a problem on cheaper components. Again, SNR doesn't matter between any digital signals, be it HDMI, S/PDIF, USB, AES, or anything else.
I dunno about the lag. If over huge distances, optical obviously wins, but on the smaller scale I'd think the decoder chips make more of a difference.
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454838
well I have an alc1150 chip
7.1+2 channel multi-streaming enables concurrent gaming/VoIP
Smart multiple streaming operation
Primary 16/20/24-bit SPDIF-OUT supports 32k/44.1k/48k/88.2k/96k/192kHz sample rate
doesn't say spdif channels
and im going to buy strix 970
what should I use  ?
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4454872
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4455627
Splitters are the way to go. Or if you wanna have a centralized volume knobs for each outputs, something like this: http://www.amazon.com/Monoprice-615220-4-Channel-Headphone-Amplifier/dp/B00H3TE5P2/ref=sr_1_1?ie=UTF8&qid=1426367208&sr=8-1
was that meant for me ?
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4455683
pioneer vsx923k it has all options
If you've got a monitor/TV hooked up to that via HDMI, just keep using HDMI.
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4456073
but I was told that the spdif on the motherboard is with supremefx tech and shielding would the hdmi have same benefits ? on a gtx970 card ?
If I can say the truth the signal is noisy lets say if I turn the volume up and no real loud sound come then I will hear a hiss like low white noise or something
when the audio driver is set to 16bit 44.1khz I can hear it with no need to up the db's
but when I set it to 24bit 192khz I hear nothing until I reach a very high level
will the spdif fix this problem or I  need to get something to balance the in\out like http://www.behringer.com/EN/Products/HD400.aspx
just for the speaker and maybe for line level instead of hdmi (and use hdmi only for dtshd and dd turehd)
Edited by Benielishackove
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4456144
If I can say the truth the signal is noisy lets say if I turn the volume up and no real loud sound come then I will hear a hiss line low white noise or something
You've probably got some kinda of ground loops picking up EMI. An optical cable should fix this, as it cannot carry electrical signals between devices.
https://linustechtips.com/topic/328082-simultaneous-audio/#findComment-4456152
