So, in my programming class, we are putting interactive buttons to different websites that we made in Adobe flash, into a text edit document for HTML a, the teacher is taking too long, I want to know, how do I do it?
Definition of programmer: someone who can consume copious amounts of caffeine; and crap out a master piece through their fingers
https://linustechtips.com/topic/326779-help-with-text-edit-and-html-buttons/
If I am understanding you correctly you may want to look into the Object HTML tag. It would allow you to add interactive flash elements into an HTML webpage.
Workstation i7-3930k | GTX 980 SLI | 2 x P2715Q (2160p) | AX1200i | H100i
Server E3-1245v3 | 24GB RAM | Be Quiet! 600W PSU | Be Quiet! Rock Pro 3
Yes please! Show me senpai
http://www.w3schools.com/tags/tag_button.asp
This place is very informative and helpful with html, give it a look.
YAS, thank you!!!
Well it's really simple, everything you need to know about the Object Tag is here. http://www.w3schools.com/tags/tag_object.asp
Also I am not sure on your level of programming knowledge, but you may want to use Notepad++ - it's a must.
Yep, this.
I use it as my normal Notepad lol, it's really good.
Yep, this.
Yes indeed, and if you are on mac, download textwrangler, i've got both mac and windows and i really like those editors :D
btw i would suggest going 100% HTML :) some devices dont work well with flash :) Interactive buttons (that look nice) can be made with bootstrap, here are some examples:
in the header tag:<link rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.2/css/bootstrap.min.css">where you want the button:<button onclick="someJavascriptFunctionThatExecutesWhenYouClickThisButton()" class="btn btn-primary">Click me </button><button onclick="someJavascriptFunctionThatExecutesWhenYouClickThisButton()" class="btn btn-succes">Click me </button>
learn more about bootstrap and the beautiful and handy things you can do with it http://getbootstrap.com/css/
show the teacher this website and maybe they will agree with me that html, css and js are the future, not flash :D
if you have any questions about any of those three things (html, css and js), message me :)
