Higher GPU clock = Lower GPU load = Lower Power consumption?
Hi! I have a silly question
This is my system:
- i5 4570
- GTX 970
I play BF4, capped at 68FPS.
I see that when I OC my card the GPU load goes down.
Does this mean that the power consumption also goes down?
I don't have it overvolted and it's with the stock power limit, even with the OC
Thanks and sorry for the stupid question :P
its probably going down because its hitting the power limit due to your overclock
so basically youre getting less performance for the same power
and this is why you increase your power limit when overclockig
... If your running 30 miles per hour, its faster than 20
Your definitely going to get there faster, but at a much greater cost of your own energy
Its the same way when you ramp your card up
Its going to handle the load Better Faster but will generally use more power since its running faster in general
TLDR
Evens out with marginal differences
it might be using more power. the higher your clock a processor the energy it requires increases whether or not you touch the voltages, since it will be drawing more current (amps). i'm assuming capping your frame rate at stock would still be under 90% load so ya, you're most likely using ever so slightly more power with the oc setup
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
I'm not hitting the power limit :/ it's a G1 Gaming 970, you can't hit the power limit at least no air :P
And Power is below 60% but I don't know if the OC changed something, the power limit is still 100% (stock)
At stock I used to get 70-75% power usage
TLDR
Thank you, I will leave it at stock then :P
