How is 32" for 1440p?
ObeseWalrus
I'm thinking of buying a 32" 1440p monitor and I would ask if the extra size over 27" is a problem?
If you want to join a really cool Discord chatroom with some great guys here from LTT and outside this community then PM me!
Pixel density is nearly unnoticeable unless you sit at six inches away from your screen. Besides, with that kind of size, you want to sit at least a foot and a half away to get a good view.
iirc that's a similar pixel density to 24" 1080p, so I personally wouldn't go 32" 1440p, but it's up to you.
RIP in pepperonis m8s
Pixels wil the bigger but if a 27" doesn't give large enough words but I gyess you could do it
