im looking for a case that offers good cooling for my dual 7990 setup. right now they get around 75-80 when playing games. but im looking for something better and better looking than the case i have right now (HAF evo xb). im looking at the silverstone RV-02 but i would like some input.
Thank you
https://linustechtips.com/topic/326476-7990-cooling/
someone tell me why this was discontinued.. http://www.newegg.ca/Product/Product.aspx?Item=N82E16811129093
anyway the define r5 is a good case for airflow
https://linustechtips.com/topic/326476-7990-cooling/#findComment-4434537
Air 540, 75-80 while under load? Don't believe it.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/326476-7990-cooling/#findComment-4434538
yeah, i replaced the stock thermal paste that they came with and that is the temps that im getting. top card (closest to I/O shield) gets to 75-80 bottom card hovers around 70
wow, thats what my dual 7970s get when overclocked
anyway, the way I dropped the most temp is undervolt. Undervolt like mad. take away all the volts. at 850mhz, they barely touch 65*C now and are quite.
https://linustechtips.com/topic/326476-7990-cooling/#findComment-4434610
$150 for literally 20 pounds of plastic struts and mesh.
and didn't seem to sell back in 2011.
https://linustechtips.com/topic/326476-7990-cooling/#findComment-4436487
silverstone FT02 and RV02 are probably the best bets for a crossfire 7990 setup, almost nothing comes close.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/326476-7990-cooling/#findComment-4438274
