Best CPU cooler with (separate item)the best thermal phase for ~$30? No higher than $40.
I'll be using it on an i7-950 at stock clock with 1.1vCore(1.10000v)
Stock heatsink is at 57 idle and 94 max(it's not an issue because I can feel heat on the heatsink)
The cooler I'm looking at to buying is the 212 evo at superbiiz for $29...
https://linustechtips.com/topic/32531-~30-cpu-cooler/
Scythe Mugen 4 SCMG-4000
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/32531-~30-cpu-cooler/#findComment-415925
hyper 212 evo or pro
Main Rig: CPU: 3570k Mobo: ga-z77x-ud5h-wb :RAM: 8gb kingson ddr3 1600 :gpu crossfire amd 290's Case: zalman z9 plus Cooler: h80i p/p SSD: nutron 120gb HDD: 2tb wd green 4tb seagate desktop
Girlfirends: CPU: 8350 Mobo 990fxa-ud3 Ram 8gb kingson ddr3 1600 gpu: his 7850 case: inwin dragon rider SSD: nutron 120gb HDD: 2tb seagate
https://linustechtips.com/topic/32531-~30-cpu-cooler/#findComment-415944
I use the hyper 412 slim as it looks awesome but there are black heatsinks which are even better. The 212 evo is a great cooler.
Listen if you care.
https://linustechtips.com/topic/32531-~30-cpu-cooler/#findComment-416301
I use the NZXT T20 I got mine a couple days ago for $22 including shipping & tax but that deal has passed yesterday.
I need to get some better thermal paste cause the stuff it comes with is CRAP, hitting 70C at 4.3 Ghz with a VCore of 1.4V I could probably lower that to 1.37 any was it only gave me 300 more Mhz than the Zalman CNPS 5X because i was using a better thermal paste with the other cooler.
CPU: AMD 3600 GPU: ASUS DUAL OC RX 6750 XT MOBO: Asus Prime X570-P RAM: 16GB XPG Gammix D10 3000Mhz
PSU: Gamdias Kratos P1 650w 80+ Gold OS:Windows 10 pro Case: 4U Rackmount  HDD/SSD:Seagate 8 TB/ Patriot Scorch m.2 512GB
You can't spell ignorant without IGN...-TheSLSAMG
https://linustechtips.com/topic/32531-~30-cpu-cooler/#findComment-416458
How about this cooler, it's $2 cheaper(shipping) than the evo on Amazon and it seems like it could cool better...
http://www.amazon.com/gp/aw/d/B00BSKY1M4/ref=mp_s_a_1_8?qid=1372972022&sr=8-8π=SL75
The Hyper T4 is an inferior cooler in every respect when compared to the Hyper 212 EVO.
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
https://linustechtips.com/topic/32531-~30-cpu-cooler/#findComment-418357
Hyper 212 Evo the way to go !
but if you could spend some more then Deepcool neptwin is also a good cpu coolerDeepcool-NEPTWIN-2.jpg
FX 6300 @ 4.2 Gigahurtz 1.325V ,  ASRock 970 Extreme 4 mobo  ,  Kingston Hyperx Blu 2X4GB @1600Mhz  , Asus GTX 960 DCU ii Black OC  , Hyper 212 Evo , Samsung 850 Evo 250 GB , WD 1 TB caviar Green , Xonar DG sound card , Seasonic M12ii Evo 620W PSU , Corsair 200R case ,4 random case fans.
https://linustechtips.com/topic/32531-~30-cpu-cooler/#findComment-423208
+1 on the Hyper 212 Evo. A great budget cooler that provides excellent cooling results. Be sure that your ram has clearance with the Hyper 212 Evo. 10_cmh212e_size.jpg
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/32531-~30-cpu-cooler/#findComment-425873
As many posts before, Hyper 212 Evo with that budget.
CPU:Intel 3770k Motherboard:Gigabyte z77x-ud5h GPU:Gigabyte GTX 660 Ti Ram:Kingston HyperX Blu 16GB Storage:Crucial M4 128GB+Seagate Barracuda 1TB Case:Zalman Z11 Plus PSU:Corsair TX650 Cooler:Noctua NH-D14 Fans:Noctua NF-P12+ Silverstone AP123 Keyboard:Corsair K90 Mouse:Corsair M60 Monitors:Dell U2412M+U2312HM
https://linustechtips.com/topic/32531-~30-cpu-cooler/#findComment-427095
