Hey guys!
I am planning to build a Haswell system in the 540 airflow case.
I will be overclocking the i7 4770k but I am not very sure which cooler to get.
I already have the Noctua NH-D14 and I know how beastly that cooler is but it is massive, and it will cover up most of my motherboard and the beautiful ram I am getting. ( I am getting the Gigabyte z87x-ud4h with vegeance pro series red and silver rams, trust me it looks sexy together)
As we know the Corsair 540 lets you have a very very clean build. So I was thinking about getting the h100i but how does it differ in performance? I never had a water cooled cpu. Also does corsair have any 280mm radiators? and are they any good?
Thanks guys!
<3
https://linustechtips.com/topic/32527-corsair-540-high-airflow-build/
H100i is a great cooler. If you want a 280mm rad corsair has the h110 but it doesn't come with the link software or the customize able LED on the block.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
AHEM*** NZXT KRAKEN BABY!!! H110 is lame!
OS - Windows 8.1 Motherboard - ASUS M5A99FX Pro R2.0 Processor - AMD FX 8350 Black Edition RAM - 16GB 2x8 Crucial Ballistix Sport Graphics Card - Gigabyte Windforce 2 OC GTX 660 Power Supply - Corsair CX750M CPU Cooler - NZXT Kraken X60 Wireless Adapter - ASUS PCE-N15 PCI-E Adapter Fans - x3 Masscool blue LED 120mm Fans Case - Fractal Design Define R4
Monitor - Dell S2230MX 21.5-inch Keyboard - Logitech G105 Mouse - Logitech G602 Speakers - Logitech Z130 Headsets/Headphones - Tt eSports Shock, AKG K240, California Headphones Laredo Phone - iPhone 4S
I would opt for the Corsair H100i instead, it will look very clean in the case, and with the right fans it would just look beast.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
Thanks for the reply! I have some more questions,
Can I change the LED on the 100i to glow red?
Is the 110 better in performance wise? I would guess it is. But how much better the question is,
Yes you can customize the LED to just about anything.
h220 with a 360 and 140 rad added would be way better than a h100...
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
the H110 performs better because it has a bigger radiator, but it has very strange screw spacing, it can only be mounted in corsair cases, and its not as new as the h100i, the H110 is only a little bit better, which wouldn't have any dramatic impact on your CPU anyways so i would get the h100i :) im getting the same case and it is awesome.
I would look at the swift tech 220
This can beat the h100i by upto 20℃
how ever in this case it won't
but it will still beat the h100i
By a noticeable margin with propper fans ofc
Because Hasewell runs HOT*!!!
Edited by mikeeginger
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
