I have no idea what the difference is between the
MSI radeon r9 290 4gb twinforzr
And the
MSI geforce gtx 970 4gb twinforzr
Please someone elaborate and point put my best for gaming
They are completely different Other than they are both GPU's.
The 290 is warmer and uses more power, but actually has 4GB of usable VRAM.
The 970 is cooler and uses less power, but has a memory problem with the last 0.5GB.
Personally:
290 if you're going 1440p+ and GTX 970 for 1080p.
But it really depends on what games you do too
https://linustechtips.com/topic/325167-radeon-or-geforce/#findComment-4416534
The GTX 970 is more powerful than the R9 290 in most ways; though the R9 290x where I live is less (CAD $) than the GTX 970 and if I were to buy something in that price range I'd personally buy the 290x instead of a 970; though if you're looking only between those two graphics cards the GTX 970 is better in almost every way.
If you dont get a stock cooler (why does everyone compare stock coolers?) the 290 doesn't run any louder or hotter.
The R9 290 won't output less heat because you put a better cooler on it.
If you've found a way to do this please call Physicist Nicolas Léonard Sadi Carnot and inform him Thermodynamics is a dead field.
HydrOS (Waterworks 3.0) Pictures: // One // Two // Three
i7 5820k @ 4.3GHz (1.165v) // Asus X99-A // 16GB-DDR4 Vengeance 2400 CAS13 // RAID 0 Intel 730 240GB // Nvidia Titan X (+200Core +500Memory) // Swiftech D5 // ASUS ROG SWIFT
https://linustechtips.com/topic/325167-radeon-or-geforce/#findComment-4416537
And the
Both are good, theres many ways to it tho,
Price: 290 is cheaper
Performance in certain games: Almost
Power Consumption: 970 is better.
If money isn't a issue and you only plan on 1080p gaming, get the 970.
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
https://linustechtips.com/topic/325167-radeon-or-geforce/#findComment-4416538
dis^
a windforce or lightning edition 290 or 290x is literally a GODLIKE gpu, id rather have it than anything else :P
https://linustechtips.com/topic/325167-radeon-or-geforce/#findComment-4416670
