Ok, so I'm trying to integrate 2x and it's not going too well.
I know how to differentiate 2x:
y=2x
ln|y| = x ln|2|
d/dx[ln|y|] = d/dx[x ln|2|]
(1/y)*dy/dx = ln|2|
dy/dx = y * ln|2|
dy/dx = 2* ln|2|
So from here how do it work it backwards?
Image if it's easier to follow.
https://linustechtips.com/topic/324562-need-help-with-maths/
do your own homework you lazy
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/324562-need-help-with-maths/#findComment-4408725
What the fudge kind of math is this? never seen it like that before O.o
calculus, extremely useful with plenty of applications.
https://linustechtips.com/topic/324562-need-help-with-maths/#findComment-4408726
If you do it by the "best guess" method, you can try 2x. When you differentiate that, you get 2xln2. That means that you need to divide by ln2 to get back to your original answer.
Therefore, the correct answer is 2x/ln2+C
HTTP/2 203
https://linustechtips.com/topic/324562-need-help-with-maths/#findComment-4408903
^This. If you wanna show  your work though:
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/324562-need-help-with-maths/#findComment-4409435
Wasn't that 2^x/ln(2)+c?
Not so sure anymore it has been a while.
I worked it out in the end. You just have to think of 2x  in terms of exponential and use substitution , aanyway it's probably easier just to take a pic of my working.
https://docs.google.com/file/d/0B-6QNewcQomZczZOTHdHaVJtWWM/edit?usp=docslist_api
https://linustechtips.com/topic/324562-need-help-with-maths/#findComment-4409442
@T.Vengeance is that done on a  surface tablet or something similar?
https://linustechtips.com/topic/324562-need-help-with-maths/#findComment-4409754
