Hello,
Do any of you have a USB drive that just has general tools installed? Such as browsers or Malwarebytes?
What programs do you have on there?
I'm putting together one out of a cheap 16gb drive I found, just wondering what most people find useful.
"Normandy" i7 4790K - GTX 970 - Phantom 410 (Gun metal) - Z97 Extreme4 (asrock) - 128GB Crucial SSD - 1TB WD HDD - H60 Refurb. - 7 case fans | G710+ Keyboard, G230 Headset, Acer GN246HL Monitor.
Quick thoughts on system: I7 is extremely quick and I'm glad I spent the extra for hyper-threading. I regret my decision to get the GTX 970, it has horrible coil whine. There isn't any excuse for this terrible whine I and others are having. I HIGHLY recommend a 144hz monitor. Future Improvements/upgrades: Rubber fan mounts, basic speakers, more ram (for a total of 16gb), replace GPU.
144hz is love. 144hz is life. I like to submit unfinished posts then do about 20 edits. I like the Night Theme too.
https://linustechtips.com/topic/324511-usb-general-tools/
I have a Windows 7 64-bit ISO on one stick
and all my drivers (should i need to reinstall) and homework on the other.
Porn is in the clouds
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/324511-usb-general-tools/#findComment-4408170
