Hello there,
I was wondering what OS Linus used on his PC for the review of the Obutto Revolution. I have a G25 and it refuses to work with my new gaming machine. The specs if my old machine are/were:
Intel Pentium CPU w/ hyperthreading @ 3.2GHz
4GB Corsair DDR2 RAM @ 800MHz
Radeon HD6670
Only USB 2.0
Windows 7 Home Premium 32-bit
(I don't know the motherboard as it came pre built, I think it was a dell mobo.)
My new PC specs are:
Intel Xeon 1230v3
MSI Fatal1ty B85 mobo
16GB Kingston Savage DDR3 RAM @ 1600MHz
Radeon HD6670 (Same as old system)
USB 2.0 and 3.0
Windows 8.1
I managed to get it working for a little while but suddenly it stopped working. I get 'Error Code 43' and 'Device Descriptor Request Failed.' I've tried plugging the G25 into different ports both on the MOBO and on the front IO. It was suggested that the MOBO USB controller had failed but if that is so, why is my keyboard, mouse and printer working?
Any help is appereciated
https://linustechtips.com/topic/324318-help-about-my-g25/
Do you need the Logitech controller software? That'll install drivers for it.
https://linustechtips.com/topic/324318-help-about-my-g25/#findComment-4405948
