I want to get into making 100% custom from scratch cases, but I can't seem to find much out there on how to approach it. My main concern is how to measure out/calculate the I/O shield, PCI slots, etc for the "backplate" of the case, and I don't want to spend hours and hours re-inventing the wheel since I know that lots of people out there make custom cases. Does anyone have, or know where I can find, insight in the case designing process so that I have a least a little idea of how the whole process works? I'm learning SketchUp, but what are the ATX standardized dimensions? Like, "How far up from the surface of the motherboard tray should the I/O cutout start?" and "How far from the edge of the I/O cutout should the first PCI slot cutout start?"
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/323520-help-with-100-custom-case-build/
Well, you could take a generic case and get measurements from that.
There are some very good diagrams online, but if you want to make a case and have the PCI-E slots done or premade you can either cannibalize them from an old case or purchase parts themselves online to help construct your case.
Parts:
http://www.mountainmods.com/motherboard-parts-c-21_34_66.html
Diagrams:
http://www.techpowerup.com/forums/threads/pc-component-dimensions.157239/
http://www.hardwarecanucks.com/forum/cases/67334-atx-expansion-specifications.html
Easiest way to do it is to rip a motherboard tray out of an old pc. Other than that there are diagrams out there, and you could also measure. Just make sure you don't forget the little slits in the motherboard tray that the little tabs on pci brackets slot into, like I did. The diagrams don't seem to show these.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
take the back panel from a mainstream case and implement that into ur design?
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
Parts:
Diagrams:
Holy crap! Thanks man! I spent literally hours yesterday going through Google image searches and reading through other forums and could only ever find crappy home-made diagrams. Those should help a TON! And yeah, I've looked at MountainMods, and I was considering it if only to make my "cherry" modding experience a little easier.
I thought about that, but the only old PCs I have are some Dell Optiplex desktops that I got for free and an old HP that has this super weird mobo mounting system, so the measurements would have been way off anyway. :-/
END OF LINE
I would not recommend google sketchup...possibly the worst kind of parametric cad IMO...if you want to start with something simple but accurate, try Autodesk Inventor or Dassault Solidworks.
As for how to go about designing something like this, your requirements will be based on the ATX specifications and SFF specs. Also make sure you understand how dimensioning and tolerancing works...seems even case manufacturers dont even grasp this simple concept. Good luck!
Yeah, I started learning SketchUp last night, and I was wondering how anyone can make accurate plans/designs with it. I'm installing a trial of AD Inventor right now, so we'll see how that goes. Don't know that I'll be able to afford a license after the 30 days though... :-/
END OF LINE
OMG... I got the 30 day trial of Autodesk Inventor today and I'm going through the tutorial.... I think I'm in LOVE!! I will find a way to buy this program, it would solve soooooo many issues for me with all the designing I like to do. Goodbye quadrille paper and pencils!!
END OF LINE
OMG... I got the 30 trial of Autodesk Inventor today and I'm going through the tutorial.... I think I'm in LOVE!! I will find a way to buy this program, it would solve soooooo many issues for me with all the designing I like to do. Goodbye quadrille paper and pencils!!
Good! We use it to create some pretty complex designs with structure and wiring. I use Autodesk Inventor, Siemens NX and CATIA v5 on a daily basis.
If you don't mind, could I add you as a friend on the forum? I would love to have someone that I can bounce ideas/designs off of if I get stuck.
END OF LINE
Sure no problem.
As for your questions on form factors, start with the ATX specifications here.
Sure no problem.
Thanks. I actually found that site earlier today. :)
END OF LINE
