Is this an overkill? this is a build for a friend VERY HEAVY work.
Any Suggestions will be appreciated. :)
https://linustechtips.com/topic/320986-pc-build-for-heavy-work/
37k for a computer. can you please define VERY HEAVY WORK?
correct me if im wrong but i cannot think of a single thing on the planet that will require them specs for a computer... let alone spending 37k on very heavy work that could be copying and pasting sentences on to word.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/320986-pc-build-for-heavy-work/#findComment-4362843
^^ this,
or I call BS on OP.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/320986-pc-build-for-heavy-work/#findComment-4362846
AUTOCAD, 3D RENDERING AT 4K, 1080p. Game design with frostbite, Maya.
https://linustechtips.com/topic/320986-pc-build-for-heavy-work/#findComment-4362872
lol fake post is fake
Even if you wanted heavy work, this is a stupid badly put together build.
https://linustechtips.com/topic/320986-pc-build-for-heavy-work/#findComment-4362873
Why would it be fake?
That is why I said if you have any suggestions... Then put it forward.
https://linustechtips.com/topic/320986-pc-build-for-heavy-work/#findComment-4362908
37k Pounds :blink:
It's aroud 10K
because there are the ridiculous SSDs?
10k each for that is too much :D
CPU: Intel i5-4690K | Mobo: MSI Z97 Gaming 3 | RAM: Kingston Savage 4x4GB | GPU: Asus Strix GTX970 | PSU: Seasonic M12II-620 Evo | Storage: MX100 128GB + WD Blue 1TB | Cooling: CM Hyper 212 evo | Case: NZXT H440
https://linustechtips.com/topic/320986-pc-build-for-heavy-work/#findComment-4362996
If they are doing work that they are being paid for, and need a dedicated GPU for it, get a Quadro or FirePro. Titans aren't supported by many modeling programs, for example Solidworks. If you're building a workstation, get workstation grade hardware.
https://linustechtips.com/topic/320986-pc-build-for-heavy-work/#findComment-4363852
You're not going to be able to fit all 5 of those PCIe devices. SLI mode on the Titans is likely bridged across slots 1 & 3 (most X99 boards are configured this way for x16 operation). You'll also run into some pretty significant temp issues if you completely populate the PCIe slots. I can't imagine why someone would need 4.8TB of PCIe storage. One OCZ R4 should be more than sufficient for using as a scratch disk/working file drive (assuming rendering/video production here). The completed file can be sent to a RAID array on standard platters. Any internet upload speed would be the bottleneck on moving around completed files, unless you were planning on using a 10gig NIC to transfer to a local file server (which I don't see in the options list).
Overkill build is overkill. 2 titans and one OCZ R4 is more than sufficient for nearly anything. If you have a specific use case for this person please detail what it is, as right now it just seems like this is a bogus build.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/320986-pc-build-for-heavy-work/#findComment-4364046
i'd rather use nvidia quadro or firepro instead rather than titan Z. and maybe some dual xeon setup.
but to be honest, this system is quite overkill for your 'heavy work'.
CPU:  i5 4690 Motherboard: AsRock H81M-VG4 RAM: Corsair Vengeance 8GB (2x4GB) 1600MHz Graphics Card: Sapphire HD7870 OC Intel HD4600  MSI R9 270X HAWX Storage: 1TB WD Blue 7200rpm, 120GB WDC Scorpio 5400 rpm PSU: Corsair VS550 Chassis: Custom Open Air Case OS: Windows 8.1 X64 Mouse: Roccat Kone Pure Optical Mousepad: Roccat Taito Keyboard: Armageddon Kalashnikov AK-770i
https://linustechtips.com/topic/320986-pc-build-for-heavy-work/#findComment-4370898
