This seem to be the best section to post this in since it has the benchmarks pinned to the top. So i stumble upon this site http://www.userbenchmark.com/and thought it was fun to play with and see how your system compares to others. It's funny how they compare components to sea vessels, my gaming/graphics got a rating of a raft :huh: , but everything else was much higher so good luck.
Here is my system
UserBenchmark PC Test Results
System Status: 82% - Excellent. Overall Score: 98% - Nuclear submarine.
CPU: Intel Core i5-4690K - Status 81%, Speed 101.2%.
HDD: WD Blue 1TB (2012) - Status 82%, Speed 106.3%.
HDD: Toshiba MK4058GSX 400GB - Status 75%, Speed 29.2%.
SSD: Samsung 850 Pro 256GB - Status 81%, Speed 115%.
GPU: Nvidia GTX 460 - Status 92%, Speed 27%.
Current build in progress http://pcpartpicker.com/p/b8FPcf
https://linustechtips.com/topic/320830-how-does-your-system-compare/
Here is my system
What the hell is userbenchmark
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
I'm lazy and I have no more space on my ssd, I have a quattro k5100m 8gb ddr5, 32gb ddr3 ram, i7, samsung 850 pro and 3k res
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
To be honest I hadn't heard of it till just now. I was looking at different CPU benchmarks and found this site and thought it had more accurate data compared to others so I thought I would share.
That website hurts my eyes. So poorly laid out, imo.
True, its layout isn't the best, but I think it is about as equally bad as CPU boss
Apparently I need to Overclock or something...
http://www.userbenchmark.com/UserRun/175904
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
*shudder*
Ares did alright. The benchmark does it no justice though since it's actually pretty damn fast for what it is.
http://www.userbenchmark.com/UserRun/175900v
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Sorry I laughed hard at Tree Trunk
!Sub-optimal ambient CPU load. These results have reduced accuracy because the CPU was active before the benchmark even started. Check CPU load with windows task manager (CTRL+SHIFT+ESC). <----------?????
Yea im not sure what that is complaining about. I mean I did have a bunch of chrome tabs open and music when I tested.
Might as well toss my laptop into the mix...
http://www.userbenchmark.com/UserRun/175916
Anyway, I need to point out; only the first DX9 test uses SLI. All the rest run single GPU only, so SLI rig users are kind of left in the dust there. It's the program's fault; as I'm on latest drivers too. But it's food for thought about the "graphics power" ranking it gives.
Those who got a higher CPU score than me with i5s, what is your frequency?
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
Trial number 2 with nothing open
http://www.userbenchmark.com/UserRun/175919
A whole few percent better?
You beat in the gaming score. Yet popular opinion on this forum would like to believe my rig should beat yours...
http://www.userbenchmark.com/UserRun/175921
"It's the Business"
That's funny, CPU is a Non-K,..GPU is stock...
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Links Broke. That is how my first link was and i had to copy the address bar.
updated
@Imabigmac
A component achieves a status of 75% when it's faster than 75 out of 100 results for the same component.
PC status is the average status of all the components in a system. When a system has a low status score its components are underperforming.
Causes of poor system status
Poor system status can be caused by either software or hardware. Software problems usually stem from rogue applications silently draining system resources.
CPU
  • Overheating (particularly in laptops) - remove dust near air vents with a vacuum.
  • Reduced battery power can put CPUs into a lowered performance state.
  • Running stock clocks on an unlocked (K, Black) CPU - many users will have overclocked.
  • High background CPU utilization - identify and terminate any offending applications.
Drives
  • USB: USB 3.0 components on USB 2.0 ports limit peak speed to 35 MB/s.
  • SSD, HDD: SATA 3 components on SATA 2 ports limit peak speed to 285 MB/s.
  • SSD, HDD, USB: high background I/O - identify and terminate the offending programs.
  • SSD, HDD, USB: RAM caching is enabled either via software (e.g. Samsung RAPID), driver error, device malfunction or via windows write cache buffer settings. Drives with these settings expose the system to data loss in the event of a power outage as they rely on temporary RAM rather than persistent storage. These results are disqualified.
GPU
  • NVIDIA Optimus/AMD switchable graphics drivers switching to an IGP rather than using the discrete "M" card.
  • High background CPU utilization can throttle a GPU.
@Imabigmac
-snip-
Im not overlocked, probably why then. Its not thermals.
@Schoolofmonkey
I was browsing the latest benchmarks and came across yours before you posted and I knew someone was about to show off....I wonder who that could be??
Wasn't my intentions...maybe... :D
Still strange I only got Battleship on the workstation score...
