Micro-ATX Case for a MSI GTX 970 Gaming 4G
Solved by brob,
The MSI GTX 970 Gaming 4G is only 141 mm tall. It should easily fit in the Fractal Design Node 804 and all of the Bitfenix mATX cases based on the Prodigy chassis - Prodgy M, Phenom micro-ATX, and Colossus micro-ATX.
Any case that is not arced over the cpu area should allow a gpu at least as tall as the max cpu cooler height.
1
ghifrank ·
Posted in Troubleshooting0 -
V_1313 ·
Posted in Troubleshooting2 -
IR76 ·
Posted in Programs, Apps and Websites9 -
The Blue Cryptid ·
4
8
