Vertical and Horizontal Refresh Rates
Why is it that the monitor I'm getting have both a vertical and horizontal refresh rate? What do those mean? http://www.newegg.com/Product/Product.aspx?Item=N82E16824236288The horizontal for the monitor is 30-83 kHz and vertical is 50-75 Hz. What does it all mean!?!? Thanks
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/319152-vertical-and-horizontal-refresh-rates/
When people talk about refresh rates or Hz, they're referring to the vertical refresh rate.
That's the one you should care about. It means this monitor can handle up to 75Hz.
Bert & Ernie before squirting spermie.
Ok thanks
