so i have decided to do my 1st build because what once was mine and my GFs computer has now become just her computer thanks to final fantasy 14.so her i am
ive done a bit of research and think i have it all figured out ... but i wouldn't mind someone who knows a bit more to take a 2nd look
CPU - i7-5820k
CPU cooling - Corsair H100i
Motherboard - Gigabyte GA-X99-GAMING G1WIFI
Memory - AVEXIR Core Series - DDR4 2666 16gb 4X4 (because pretty lights)
Storage - Seagate 2TB 3.5" 7200RPM Hybrid Internal Hard Drive
Graphics Card - EVGA GeForce GTX 980 4GB Superclocked ACX 2.0
Case - Corsair 750D
i plan on using this for gaming and possibly live streaming . i would like to be able to use 3 monitors at some point as well
https://linustechtips.com/topic/318923-first-build-any-problems/
An SSD is also well worth getting.
CPU I7 - 4720HQ RAM 2 x 8GB • GPU Nvidia GTX 850M Storage 250GB 850 EVO - 1TB Seagate Hybrid
Keyboard CM Storm QuickFire Rapid-I (MX brown) & Pok3r (MX clear) • Mouse Logitech G502 • Sound Audio-Technica ATH-M50X • OS Windows 10 Pro - Linux Arch
Storage Asustor AS7004T
https://linustechtips.com/topic/318923-first-build-any-problems/#findComment-4335596
^this. get a samsung EVO 128gb for OS :)
Or a bigger one to put some games on as well.
https://linustechtips.com/topic/318923-first-build-any-problems/#findComment-4335619
Then get this. I went completely overkill with the CPU cooler and case, for pure looks (I just find them so gorgeous...). I mean, the CPU cooler is also super powerful, but you don't need all that cooling.
Red theme. Can easily change. Have fun.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($322.99 @ SuperBiiz)
CPU Cooler: RAIJINTEK TRITON RED 100.5 CFM Sleeve Bearing Liquid CPU Cooler  ($99.90 @ Newegg)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($115.99 @ SuperBiiz)
Memory: A-Data XPG V1.0 8GB (1 x 8GB) DDR3-1600 Memory  ($59.98 @ OutletPC)
Storage: Apotop  256GB 2.5" Solid State Drive  ($89.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.99 @ NCIX US)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card (2-Way SLI)  ($328.99 @ Directron)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($115.99 @ SuperBiiz)
Power Supply: Rosewill 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($64.00 @ Newegg)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($86.99 @ NCIX US)
Total: $1661.80
Generated by PCPartPicker 2015-02-28 05:31 EST-0500
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/318923-first-build-any-problems/#findComment-4335637
That all looks fine, but in all honestly the CPU + CPU cooler and Mobo really is overkill really, if you're only doing gaming + live streaming. The streaming will put a bit of stress on it if you're using an intensive compression but an i7 4790K would handle it just as well. Same as the DDR4, it's not gonna yield any better results with anything you're doing, unless you all of a sudden decide to run some really CPU intensive programmes
https://linustechtips.com/topic/318923-first-build-any-problems/#findComment-4335641
lol i knew i was forgetting something on that list
power - EVGA 850W 80+ Gold
and ill have to check out some SSDs as well
and i know some of the parts are a bit overkill and all but i i like the looks lol
Imakuni u are right that cooler is pretty sexy lol i might have to get that one
https://linustechtips.com/topic/318923-first-build-any-problems/#findComment-4335702
Yay, another Triton-nist.
BTW, 850w is actually a bad choice. It would be suited to drive 2x 290s, but for the 9xx series, the power consumption is below the required TDP.
https://linustechtips.com/topic/318923-first-build-any-problems/#findComment-4335806
How much power would u recommend
If using the Asus Strix 970/980, a 500 or 550w PSU will do. If using any other brand, you'll need a 650w, solely due to the need for extra PCIe connectors.
https://linustechtips.com/topic/318923-first-build-any-problems/#findComment-4336198
