So my stepdad's old computer has a Socket 462 CPU (a Sempron 3000+, as I recall), and there is a chance he might turn it into an old-school gaming computer. I would like to get a better heatsink for it though, since the stock one sucks. I was thinking about trying to snag a FX-series heatpiped cooler from someone on here for cheap, but I'm not sure if the two are interchangeable. I know that AM2+ and up are all compatible, and apparently the FMx sockets will work with the AM2+ heatsinks as well.
EDIT: @DEcobra11, getcho ass in here! :D
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/318657-socket-462-cooling/
Already have the heatsink in the Amazon link, and I was kinda thinking the new FX-series heatpiped cooler from someone on here if it is compatible, since when I had mine it was freaking quiet for a stock cooler.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/318657-socket-462-cooling/#findComment-4331908
ln2
B)
Watch out for each other. Love everyone and forgive everyone, including yourself. Forgive your anger, forgive your guilt. Your shame. Your sadness. Embrace and open up your love, your joy, your truth, and most especially your heart.
-Jim Hensen
https://linustechtips.com/topic/318657-socket-462-cooling/#findComment-4332023
I once read the mounting holes aren't in the same place but the clips are. So stock coolers should be worth a try. Do you have one spare?
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
https://linustechtips.com/topic/318657-socket-462-cooling/#findComment-4332031
ln2
B)
No. :P
Actually, I do. But it's not at my grandma's where the computer is. :P
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/318657-socket-462-cooling/#findComment-4332037
No. :P
alright.y :P
-Jim Hensen
https://linustechtips.com/topic/318657-socket-462-cooling/#findComment-4332776
By any chance is this the kind of cooler you're looking for?
STOP using prime95 with Haswell CPUs!
Main Rig:
CPU:i5 4690k @ 4.6GHz, Motherboard:ASUS Z97-A, GPU: EVGA GTX 970 FTW, PSU: EVGA Supernova 1000 G1, CPU Cooler: Cooler Master Nepton 240M w/ Noctua NF F12s, Case: NZXT S340, Memory: 16GB (4X4GB) G Skill Ripjaws X 2133MHz, Storage: Samsung 840 Evo 256GB boot drive & Seagate Barracuda 7200 rpm 2TB
Secondary/Folding Rig:
CPU:FX 8320 @ 4.6GHz @ 1.344 v., Motherboard: ASUS M5A99FX, GPU: MSI R9 290 Gaming, PSU: Corsair HX 750, CPU Cooler: be quiet! Dark Rock Pro 3, Case: NZXT Source 530, Memory: 8GB (2X4GB) G Skill Ares 1600MHz, Storage: Samsung 840 Evo 128GB
https://linustechtips.com/topic/318657-socket-462-cooling/#findComment-4334488
754, 939, AM2, AM2+, AM3, AM3+, FM1, FM2, FM2+ Use the same mounting system, but bad news: it's wider than 462. Unless you've true cianoacrilate (not chinese that breaks instantly) and you've enough space glue the mount (obviously no backplate)
Also my 462 mb doesnt have holes (Dunno yours) so zipties impossible. If you can take a pic from top and below I'd try some "RD"
If you are interested socked 462 cooler mount = socket 370, Arctic Freezer 7 Pro Rev 2 w/o the metal crap for mounting + stock mounting clip over the pipes works <- Gonna make a tutorial 4 this now
Oh pooey. I'd be doing this on the ASUS A7VBX-LA, so there's no holes. At least I found a nice Cooler Master heatsink on eBay for it. With luck it will be able to handle an Athlon XP 3000+. :D
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/318657-socket-462-cooling/#findComment-4336256
my XP 2600+ was OCed higher than that... tho yours has double L2
Ok, new cooler then, seems like you've the same problem as me... too many shit around the socket to glue other mounting systems
BTW, it's a Cooler Master X Dream II. :D
Not saying this Sempron 3000+ is painfully slow... But it is.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/318657-socket-462-cooling/#findComment-4336343
Yeah Socket A(462) does not share coolers with S939 or any of the AM series, and the S939 coolers are just a bit different from AM2/3.
Socket A uses an old style retention bar that clips to the socket itself, not a bracket around it.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/318657-socket-462-cooling/#findComment-4340864
