Should I get these fans because my pc is loud at the moment. Im using nzxt led fans, been watching some videos reviewers have said it isn't cheaply made and a lot of work has gone into it. I can actually see that there's been work put into it and isn't just a fan.
http://m.ncix.com/products/sku/100139/
@KayTees' Little Brother
My PC: Stepping Stones (2019)
CPU: Intel Core i7 8700
CPU Cooler: be quiet! Dark Rock Pro 3
Motherboard: GIGABYTE B360 HD3
RAM: HyperX Fury 8GB (2x4) Black DDR4-2133GHz
GPU: MSI GeForce GTX 1070 Ti Titanium 8GB
Case: Thermaltake View 27
Storage: SanDisk 2.5" 128GB SSD | Western Digital 3.5" 1TB HDD
PSU: EVGA SuperNOVA G3 550W
Displays: LG 27GL63TBenQ GW2270 21.5"
Keyboard: Corsair Strafe w/ Cherry MX Red Switches & 2010 Razer Blackwidow w/ Cherry MX Blues Switches
Mouse: Logitech G502 Proteus Spectrum
Headset: V-MODA Crossfade M-100
Operating System: Microsoft Windows 10 LTSC
Last updated: August 10, 2020 at 2:10 PM
Mobile Devices:
Phone: OnePlus 7 Pro Almond (OnePlus GM1917)
Tablet: Samsung Galaxy Tab 4 8" (SM-T330NU)
Previous Phones: Apple iPhone 4, Apple iPhone 5, Samsung Galaxy Note 4 (SM-N910W8), OnePlus 5T (OnePlus A5010), OnePlus 6 (OnePlus A6003)
PCPartsPicker:
PCPartsPicker Link: http://tiny.cc/KenTees
Last updated: April 23, 2019 at 2:00 PM
https://linustechtips.com/topic/317337-fan-worth-it/
Never heard of them.
For silence i would go with be quiet or noctua
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/317337-fan-worth-it/#findComment-4312740
They're good but should be closer to $10 than $20.
If you state your budget and specs, we could probably give some better alternatives.
https://linustechtips.com/topic/317337-fan-worth-it/#findComment-4312742
Budget isn't a problem, I'm using 2 Corsair AF 120 for the front, both of them are intake with a filter, the top, I have one Nzxt led and corsair air something (came with brothers h80i, replaced his with led fans instead) for exhaust and also another corsair one near the IO for exhaust.
Mobile Devices:
PCPartsPicker:
https://linustechtips.com/topic/317337-fan-worth-it/#findComment-4312791
Rest of specs? It would help to know the case and components being cooled.
Where are you shopping/located?
https://linustechtips.com/topic/317337-fan-worth-it/#findComment-4312804
A8 6600k,MSI A78-E35, R9 270X, Corsair Spec 01. Most major components. Mostly prefer NCIX or Memory Express, either pick up or 1-2 day shipping to my house.
Mobile Devices:
PCPartsPicker:
https://linustechtips.com/topic/317337-fan-worth-it/#findComment-4312823
What cooler are you using on the cpu?
https://linustechtips.com/topic/317337-fan-worth-it/#findComment-4312893
The one that came with the processor
Mobile Devices:
PCPartsPicker:
https://linustechtips.com/topic/317337-fan-worth-it/#findComment-4313799
Is that also loud?
https://linustechtips.com/topic/317337-fan-worth-it/#findComment-4313850
