I assume you already have coolant or are getting it somewhere else :P
Intel 3570K - MSI GTX 660Ti 3GB OC Edition - 16GB Corsair LP RAM - ASRock Extreme4 Motherboard - Corsair HX850 - Adata Premier Pro SP900 120GB SSD with Windows 7 - Seagate Barracuda 1TD HDD - Seagate Barracuda 500GB HDD - Thermaltake Frio CPU Cooler - CM Storm Enforcer Case - Macbook Pro Early 2011 Laptop
Thanks man, just saved me $14.
I'm glad you learned from me lol. I bought fittings for mine and I was rather mad when I didn't need them. Make sure you buy some clamps to hold the tube on. I had to use cable ties since I didn't want to wait.
Personaly i would ditch the reservoir to and get a d5 top bay res d5 top will increase pump performance also, but yeah looks like you got everything right.
I checked this option out, but I don't have room for a dual bay res, otherwise I would've. Thanks for the suggestion.
Do i need coolant? Can I just go to local grocery store and buy distilled water?
for your first, yeah the distilled water is fine. plus buy enough for a rinse/flush for
the radiators. a biocide would be nice to fight fuzzy growths in the loop or a kill
coil since no nickel is in the loop.
fans?
airdeano
fans?
airdeano
Don't know what biocide/kill coil/nickel means? Do you have a link for info on that?
For fans, I have a bunch of Gentle Typhoon 2150 that I got a while back that I ended up not using.  Those should be fine?
http://en.wikipedia.org/wiki/Biocide
http://www.dazmode.com/store/product/uber_pure_killcoil_99_9991_silver_wire_0_25mm_-_250mm/
yes gentle typhoons work well on rads.
