Hi, I have a Samsung Note 4 and looking at buying a Qualcomm Quick Charge 2.0 Tenergy 18W Turbo USB Universal AC Wall Adaptive Fast Chager.   Are there special USB cables you have to get to take advantage of this technology?    I see speical Quick Charge 2.0 cables listed on Amazon and I see other standard USB cables with reviews saying that they work with Quick Charge 2.0.    Are Quick Charge cables design different?    Thanks.
David
https://linustechtips.com/topic/316045-qualcomm-quick-charge-20-usb-cable/
I highly doubt it. Any cable should work fine.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
Every cable is different because of the resistance of the wires inside the cables. A more expensive cable will have lower resistance and thus, higher current flowing through the cable (voltage divide resistance is current). This is why the really cheap cables that you can get from various sellers on ebay do not charge as fast as the cable that comes with your phone.
