Hello and welcome to my first gaming pc build! which i did 3 years ago, but im still very happy with how it performs and would like some feedback!
(dont comment on my cable management i know its bad and im too lazy to fix it, i guess im kinda nostalgic to see how far my skills have came since this build)
i also just bought 2 new fans for it actually ;(Corsair Air Series AF140 CO-9050017-PLED 140mm Purple LED Quiet Edition High Airflow Fan)
one to switch out a 120 on the bottom and one to place on top because i just wanted more colour tbh.
im also planning on buying a new case for it as well, but putting my old windows xp computer inside it for a bit just for irony.
the case being an NZXT SWITCH 810 White CA-SW810-W1 Steel / Plastic ATX HYBRID Full Tower Gaming Computer Case
anyways the specs of my computer are,
CPU: I7-3930k
Motherboard: ASUS sabertooth x79
RAM: Patriot DDR3 2x8 (16gb)
GPU: EVGA gtx 670 4gb (1 way sli)
Case: thermaltake overseer rx-1
Storage: intel 730 series 480gb
PSU: coolermaster silent hybrid pro 850w gold
Monitor: Benq XL2411Z
post-192931-0-70789300-1424641752_thumb.
post-192931-0-18877200-1424641791_thumb.
if you have any cool ideas or thing i could improve to make my computer better feel free to comment about it! i also would love to hear what you think of it based off what you see!
PC SPECS:
CPU: I7-3930K
Motherboard: Asus X79 Sabertooth
RAM: something 8x2 16gb
GPU: EVGA gtx 670 4fb
Storage: Intel 730 series 480 gb ssd
PSU: Coolermaster Silent pro hybrid 850w
Monitor: Benq XL2441Z
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/
Nice Rig!
You could make that cable management better by stuffing those cables behind the motherboard tray and routing them through the grommets,
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4288968
iM SORRY COOLAX I MEANT TO HIT THE 1
PC SPECS:
CPU: I7-3930K
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4288981
Thank god youre getting a new case
I WAS young and dumb and thought it looked cool
PC SPECS:
CPU: I7-3930K
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289013
Nice build man! I would upgrade your GPU, but im not saying its bad.. its just quite old, and a 970 would be a nice replacement! :P
i know i probably should, but it definitely has been working great for me so far!
PC SPECS:
CPU: I7-3930K
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289024
Nice Rig!
thanks!, yeah i definitely should... you know what i think ill do that. ill post pics when i fix the cable madness
PC SPECS:
CPU: I7-3930K
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289075
"Gtx 670 (4-way sli)"?
You say you have 4-way sli but have only 1 gpu installed? And dayuuum that case is ugly haha but everyone has its own taste :P
Hows that 4 way sli?
It says ''1 way sli'' for me. Which is pointless but kinda funny.. i guess.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289084
I FIXED IT I ACCIDENTLY HIT WRONG KEY
PC SPECS:
CPU: I7-3930K
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289097
Cool rig. If you wanna improve it you could just replace the GPU. That CPU will last you a good while longer.
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289105
Hey edited it :)
I figured he might have but didn't see the ''edited by ...'' anywhere. So i guess i look like a dumbass now thanx OP :/
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289122
ive been thinking of replacing it for quite a while now. i'm just really cheap and in the mindset of "why change something if it aint broken"
PC SPECS:
CPU: I7-3930K
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289130
Haha then its not called sli, just 1 gpu
 fIGHT ME SH IM TIRED
PC SPECS:
CPU: I7-3930K
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289148
things ive learned trying to redo the cable management that i did 3 years ago:
this case doesn't have the best cable management
PC SPECS:
CPU: I7-3930K
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289595
CPU: I7-3930k
Re do your cable management. You have a windowed case make it look nice inside and help alirflow
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289607
yeah im actually redoing my cable management right now, ive only gotten this far because this case has sorta under par cable management, heres what ive got so far
(bottom fan is going to stay like that for now because i just bought new fans and ill be replacing it anyways so ill fix that then)post-192931-0-58194000-1424647740_thumb.
PC SPECS:
CPU: I7-3930K
https://linustechtips.com/topic/315596-my-first-gaming-pc-build/#findComment-4289679
