Windforce fans dead - replacement help?
Go to solution Solved by Guest,
any suggestions for a fairly cheap one around 100$?
You could probably pick up something like a 280x or something like that on craigslist or ebay.
I was wondering if anyone here has had experience in replacing gpu fans.
It looks like i'd be comfortable putting on a kraken g10 onto this card without problems, but that looks like it would cost me at least 45 bucks minimum. even with a ghetto solution.
So, if i could replace the fans for 10-20 bucks that would be ideal...but i don't know how to go about obtaining/replacing these fans. Any help would be appreciated even if you just tell me its a lost cause.
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
https://linustechtips.com/topic/315518-windforce-fans-dead-replacement-help/
Contact Gigabyte, if the card is still under warranty they will most likely do something about it.
"Rawr XD"
I wouldnt replace them as i dont think you can buy replacement fans.
I would do one of the following.
1. Watercool
2.RMA
Its a rather old card that's only worth around 60$ on the bay just for extra info
so, way out of warranty
What card is it?
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
In that case i would try to replace it but be prepared for the worst. If it that old i would reccomend getting a new one.
The Windforce cooler tends to be very friendly with having 120mm fans strapped to it.
I somehow acquired another windforce 6950 today...so I can use that one, however I have some thermal pads on the way, as well as some mx-2 since I wanted a non conductive thermal paste, how would one go about attaching said fans?... also if i'm using a 700W psu would i be okay cross firing these?
If my calcs are right max crossfire would draw would be 589W, not sure how close I should get my psu isn't 80+ to my knowledge.
The 6950 and 280x cannot be cf'ed.
It should be pretty easy to attach the fans using zipties.
I meant I picked up ANOTHER 6950
Edit: so if i get this one new fans then i will have 2 working ones.
A decent 700w would be enough for a 6950 cf.
I had a Gigabyte GTX 570 Windforce that I was able to take a few screws out of the front metal casing of the card and kinda loosened it without completely taking it apart to get to the fans. I then took out the dead fan and looked up the fan's part number and was able to find a replacement on eBay for around 10 bucks.
