problems with a mechanical keyboard
i have a razer black widow which is a mechanical keyboard and i love it. But the problem is it is just too loud. My mic is a blue yeti which picks up alot of noise so when the keys make their clicking noise my friends are always complaining of it being to loud. Should i buy a non-mechanical keyboard or is their another option.
https://linustechtips.com/topic/311759-problems-with-a-mechanical-keyboard/
I'd go for a mechanical keyboard with MX Browns in it for quiet typing, and I think that clears are pretty quiet too.
You could try some O-Rings too.
you should have got a keyboard with Cherry MX brown switches and some o-ring dampeners.
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
Get some soft O-rings for your key caps. You can find kits online(WASD has a couple, but they are expensive. Banggood has a pretty cheap kit).
Two solutions, get Browns and put O-rings on them, the other is get a boom arm and position your mic closer to your face.
AD2000x Review  Fitear To Go! 334 Review
Speakers - KEF LSX
Headphones - Sennheiser HD650, Kumitate Labs KL-Lakh
