hey i have a fairly high end build (r9 280x,4690k) but i am moving to year 11 and i need a laptop to take to school and do my work on. Im looking for a gaming one.
My plan was to sell my pc and use the money to buy a laptop but then i came across the alienware laptops with graphics amplifyier. Is it worth it to spend 500bucks more than i wanted to to have a dock to plug my laptop in when i get home or is the standard gtx 860m msi and asus laptops good enough for a few years???
My budget is $1500 australian which is like a 1200 dollar laptop in america. I would prefer an i7 and at least 8gb ram. Im willing to go higher in budget if its worth it.
https://linustechtips.com/topic/311405-please-help-urgent-pc-help/
Please for the love of everything that is holy. Don't buy an alienware.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
First of all this is most certainly not
URGENT PC HELP
And secondly, no, it's 100% not worth it to get a graphics amplifier when you own a desktop. Spend that money on upgrading your desktop or keep it for the future.
sudo chmod -R 000 /*
If u can - get a normal pc, it's far better for games/work and durable, than a laptop.
And yeah, don't buy alienware - u'll just give away your money.
No. This is school. School that you generally don't live at. A laptop is essential.
Sig under construction.
I found an australian manufacturer who makes 13inch laptops with
Gtx 860m
i7 4710hq
16gb ram
250gb ssd
For 1489 is that worth it or shoild i spend more for the alienware so that when i get home i can play proper games with proper settings. By the way the alienware with the same specs is around 1800bucks
Gtx 860m
i7 4710hq
16gb ram
250gb ssd
That laptop is pretty good for the money, I'd go with that one. Once gain, don't bother with alienware. And at home you have your own desktop, why would you want to use a laptop?
