Best possible fan
Go to solution Solved by Shaqo_Wyn,
budget is about 35-45 euros
@Shaqo_Wyn
That's enough for NF-A14's. As long as you don't run them at or near the max rpm. they're quiet and they push a whole lot of air and static pressure.
I quite like Noctua...
So original i know?
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/310113-best-possible-fan/#findComment-4215939
@Shaqo_Wyn
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/310113-best-possible-fan/#findComment-4215962
any heatsink fan sugguestions ?
Depends on how much room you have in your case and how much cooling you need.
Here are some:
Big dual-heatsink: Noctua NH-D15, Be Quiet Dark Rock Pro 3, Phanteks TC14PE, Cryorig R1 Ultimate
Smaller single heatsink: Noctua U14S
Great and cheap: Cooler Master 212 EVO.
https://linustechtips.com/topic/310113-best-possible-fan/#findComment-4216125
