Ok some of the parts in this log are old but believe it or not are brand new unopened a couple of years ago i bought the z77 sabertooth a 3770k a Phantom 410 and 16g corsair vengeance ram thennnn.... my partner and i had a child so the build got put on hold,2 years later we had another i thought the rig would never get done, but finally last week i got the last of what i needed to finish it.
Im no photographer but here goes.
CPU i7 3770k
MOBO ASUS Z77 Sabertooth
RAM 16g Corsair Vengeance 1600
PSU EVGA Supernova G2 850
GPU EVGA GTX 980  SC (cheaper than reference not sure why)
STORAGE Samsung 850 Pro 256
COOLING NZXT Kraken x61
MOUSE Razer Death Adder Chroma
KEYBOARD Razer Black Widow Chroma
AUDIO Razer Kraken Pro 7.1 Chroma (a Christmas gift from the missus which started my razer trend)
post-67911-0-42690800-1423868485_thumb.j
THE RIG
CPU: i7 3770K @ 4.9 COOLER: Kraken X61 MOBO: Z77 Sabertooth RAM: Vengeance 16gb @1600 GPU: ASUS ROG Strix GTX 1080 PSU: EVGA Supernova G2 850w SSD: 850 Pro 256Gb    CASE: B/W phantom 410 AUDIO: Kraken 7.1 Chroma MOUSE: Death Adder Chroma KEYBOARD: Black Widow Chroma MONITOR: Triple 23" Apple Cinama Displays   VR: HTC Vive & Oculus Rift DK2
https://linustechtips.com/topic/309905-building-my-rig-finally/
Some of you might know the kraken x61 isnt a direct fit but pretty close so with new holes drilled it fit... just.
post-67911-0-03789000-1423868842_thumb.j
post-67911-0-41578900-1423868848_thumb.j
i forgot to get a photo but under the top cover of the 410 there are clips and screws that hold the grill in place so by removing one of the clips the top cover was able to go back on without touching the rad
THE RIG
https://linustechtips.com/topic/309905-building-my-rig-finally/#findComment-4213006
I approve of the Sesame Street in the background.
Yer the dining tv is for the kids so its mainly sesame street or adventure time
THE RIG
https://linustechtips.com/topic/309905-building-my-rig-finally/#findComment-4213114
The the motherboard, cpu, ram, fans in and water block secured
post-67911-0-63027200-1423870116_thumb.j
the psu in
 post-67911-0-54148300-1423870122_thumb.j
THE RIG
https://linustechtips.com/topic/309905-building-my-rig-finally/#findComment-4213171
Card and SSD in i don't know if NZXT done the by design but when you take the additional hdd cage out an ssd fits perfectly inside the bracket, I used removable double sided tape to hold it in place
post-67911-0-54077700-1423871129_thumb.j
with the back panel on and the cable management done
post-67911-0-50149900-1423871205_thumb.j
post-67911-0-12876900-1423871210_thumb.j
post-67911-0-27145700-1423871218_thumb.j
post-67911-0-92271100-1423872841_thumb.j
THE RIG
https://linustechtips.com/topic/309905-building-my-rig-finally/#findComment-4213278
Nice, same mobo as me! The best looking Sabertooth ever IMO :) Just an idea, maybe get rid of those tiny mobo fans, I've had mine for over 2 years without them, never a problem, it'll look cleaner and you won't have to put up with that whiny sound they make, just a thought..
https://linustechtips.com/topic/309905-building-my-rig-finally/#findComment-4213376
would it make much difference to the system temps
THE RIG
https://linustechtips.com/topic/309905-building-my-rig-finally/#findComment-4213430
